Need part # for "L" cover around alternator - Pic Attached
Postby 1337computing » Thu Jun 02, 2016 2:50 pm
I cant seem to find a part # for that thing anywhere. Mines cracked and hitting my serpentine belt. Need to get it replaced ASAP, any help greatly appreciated, picture is attached.
Engine Pic
1990 Celica All-Trac Turbo ST185
3" Berk DP, 3" Straight Piped, Magnecor Wires, EBC+
1337computing
Re: Need part # for "L" cover around alternator - Pic Attach
Postby yyonline » Thu Jun 02, 2016 5:22 pm
It's not available separately. It's part of the wire harness, which has been discontinued by Toyota. You'll have to find a used one.
yyonline
Postby 1337computing » Thu Jun 02, 2016 6:30 pm
Well sonova bitch, thanks for the info.
1337computing
Postby underscore » Thu Jun 02, 2016 6:45 pm
Maybe check the wreckers for any 3S powered cars from that era, one of them might use the same piece
Postby yyonline » Fri Jun 03, 2016 5:40 am
underscore wrote:Maybe check the wreckers for any 3S powered cars from that era, one of them might use the same piece
They don't. I checked. 3S-GTE MR2 had the alternator in a completely different spot. 3S-FE/GE Celicas and Camrys don't have the wires routed quite the same in that area.
Once you do find one, you may want to fabricate a bracket for the lower mounting bolt if you have an aftermarket downpipe. The stock downpipe has a stay with a bolt hole for the wire harness mounting bolt. On my car, this was loose and caused the issues with the alternator belt rubbing on the wire harness.
yyonline
Postby alltracman78 » Thu Jun 16, 2016 10:05 am
Yes, you want something there to hold the harness away from the belt.
I cut off the end of the stock bracket and used it.
Postby 1337computing » Fri Jun 17, 2016 11:24 am
I'll have to take a closer look and fab something up. Thanks guys.
1337computing
