Hi everyone, question in regards to this part.
Postby MrMcQuacker » Sun Jun 05, 2016 4:00 am
I need this part http://www.partsgeek.com/k7js9wv-toyota ... uum+Switch
But it's telling me I need this part http://www.partsgeek.com/catalog/1988/t ... witch.html
please let me know. Also if this part can be found on regular 3sge or 3sfe or even the v6 cameraII'lljust junk yard Iit tomorrow :) thank you
MrMcQuacker
Re: Hi everyone, question in regards to this part.
Postby yyonline » Sun Jun 05, 2016 4:11 am
They can be found on a lot of pre-mid-90s Toyotas. There's not much too them - as long as it threads in it should work fine regardless of what model it came out of. It opens up when the engine reaches operating temperature and air should pass between the two ports. When cold, it should be sealed off, and air should not easily pass between the two ports.
yyonline
