Boost leak test
Boost leak test
Postby Rallly » Tue Jun 07, 2016 12:31 am
I want to do a boost leak test. Do I just remove the intake hose/filter box off the turbo and block turbo coupler(battery side) with soup can?, then feed air(15psi) into the intake manifold??
Rallly
