Oil filter adapter o-ring
Postby ___Scott___ » Thu Jun 09, 2016 5:19 pm
In the photo below (borrowed from turbomr2.com) the orange o-ring # 15517-88380 is shown for the 2nd gen 3SGTE. Does anyone know if it is interchangeable with the one on the 1st gen 3SGTE?
I just talked to the local dealer parts guy and he tells me that it's no longer available for the 1st gen. When I asked about interchangeability he just gave me a blank stare.
I got the impression that he has been working the parts counter for about 15 minutes, I've never seen him there before.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Re: Oil filter adapter o-ring
Postby Locker » Thu Jun 09, 2016 5:59 pm
Hope this helps. from toyodiy.com
Part 96732-19019 (RING, O (FOR POWER TAKE-OFF SHIFT LEVER)) was found on the following models:
Date range Model Frames/Options Found in diagram
01/1990-05/1995 TOYOTA MR2 SW20,21 15-03: ENGINE OIL COOLER
08/1987-07/1989 TOYOTA CELICA ST16* 15-02: OIL FILTER
09/1989-08/1993 TOYOTA CELICA AT180,ST18* 15-03: ENGINE OIL COOLER
Part 15517-88380 (RING,O(FOR OIL COOLER BRACKET NO.1)) was found on the following models:
90 ST185
Locker
Postby ___Scott___ » Thu Jun 09, 2016 6:35 pm
That's what the computer says, but if I bought the o-ring for the 2nd gen 3SGTE would it work in the first gen 3SGTE. The computer info doesn't support that, but that doesn't mean it won't work.
Has anyone compared the two and have first hand knowledge of their similarity?
Scott
SONY
___Scott___
Postby yyonline » Fri Jun 10, 2016 4:05 am
15517-88380 is approximately 65mm outside diameter, 3mm thick o-ring.
You can also try 96732-31060 as well as a possible replacement. That was spec'd on the early ST185s.
They're cheap enough I'd just order them and see what fits, or doesn't.
yyonline
Postby ___Scott___ » Fri Jun 10, 2016 3:42 pm
yyonline wrote:15517-88380 is approximately 65mm outside diameter, 3mm thick o-ring.
That's pretty close. I pulled the oil filter adapter off my old ST165 and grabbed some measurements. Looking at the way the o-ring fits in the groove in the photo above, I'd say that 65mm is pretty close to fitting. The 3mm thickness is about right too.
Thanks, that is very useful information.
Scott
SONY
___Scott___
Postby ___Scott___ » Mon Jun 27, 2016 3:53 am
I went ahead and ordered the o-ring shown above, part# 15517-88380, to see if it would fit. It is bigger than the groove, but it's possible to squish it into the groove. It's not even that tough to get it in when the o-ring is dry but, since you should never install an o-ring dry, I lubed it up and found that it's a lot trickier to get in. It's still possible though and it stays in place while you bolt the adapter back to the block.
Here it is just resting in one side of the groove:
Here it is squeezed into the groove:
It remains to be seen if it leaks less than the old one, but I can't imagine it could be worse.
Scott
SONY
___Scott___
Postby Locker » Mon Jun 27, 2016 11:08 am
hopefully it works!
90 ST185
Locker
