How to remove the head bolts on a 90 alltrac
Postby awdmofo » Mon Jul 11, 2016 10:05 pm
Have the valve cover removed and before I remove the intake manifold and the turbo I wanted to ask what tool is used to remove the head bolts. This video below says a "12 point" socket, anyone know a part number or another name for it?
(Go to 4 mins into the video to hear him talk about it)
https://www.youtube.com/watch?v=BckKpYCQYM4
2013 Camaro LS 6-sp (daily)
2005 Yamaha R6 (sold)
2001 Spider (sold)
1990 alltrac (sold)
1991 MR2 turbo x2 (Sold)
awdmofo
Re: How to remove the head bolts on a 90 alltrac
Postby zaluss » Mon Jul 11, 2016 10:30 pm
awdmofo wrote:Have the valve cover removed and before I remove the intake manifold and the turbo I wanted to ask what tool is used to remove the head bolts. This video below says a "12 point" socket, anyone know a part number or another name for it?
IIRC its a 12 point 12mm hex socket.
http://www.lowes.com/pd/Kobalt-1-2-in-D ... et/3387370
zaluss
Postby awdmofo » Mon Jul 11, 2016 10:43 pm
that seems right but I believe I need the male socket not female :shrug: .
2001 Spider (sold)
1990 alltrac (sold)
awdmofo
Postby Locker » Tue Jul 12, 2016 1:10 am
its a 12 point female socket.
I've done it with a regular 6 point but wouldn't recommend it if you plan on reusing them
90 ST185
Locker
Postby underscore » Tue Jul 12, 2016 5:35 am
You can buy the sockets, but the ones I've found are in sets and pricey (considering how little I'd use them) so I usually cheat and get a bolt and 2 or 3 nuts that are the size you need and in the highest grade available. Tighten them together and weld the last nut to the shaft of the bolt, then just use a normal socket on that to remove the bolts.
Postby awdmofo » Tue Jul 12, 2016 5:35 pm
Locker wrote:its a 12 point female socket.
If this is correct, does that mean the mr2 3s-gte has different bolts? I ask because the video I linked shows a male type socket and I don't mind spending the $$ to get the right tool for the job.
2001 Spider (sold)
1990 alltrac (sold)
awdmofo
underscore wrote:You can buy the sockets, but the ones I've found are in sets and pricey (considering how little I'd use them) so I usually cheat and get a bolt and 2 or 3 nuts that are the size you need and in the highest grade available. Tighten them together and weld the last nut to the shaft of the bolt, then just use a normal socket on that to remove the bolts.
:nono: aren't the sockets like $10??? lol
2001 Spider (sold)
1990 alltrac (sold)
awdmofo
Postby RedCelicaTRD » Tue Jul 12, 2016 6:12 pm
What you are looking for is a 12-point spline bit or a triple square bit. They are easy to find online.
Postby RedCelicaTRD » Tue Jul 12, 2016 6:13 pm
Also, are you switching over to studs or will you be using stock bolts again?
Postby underscore » Tue Jul 12, 2016 6:50 pm
Maybe, to me that's still a lot for one socket I'll use once or twice. I needed a 14mm for my Jeep and I could only find it in a big $30 set so I built that for $2.
Postby alltracman78 » Wed Jul 13, 2016 1:14 am
It's not correct. Stock headbolts use a male 12 point socket.
If you have studs, then you'd use a regular socket.
Postby awdmofo » Wed Jul 13, 2016 3:46 am
RedCelicaTRD wrote:Also, are you switching over to studs or will you be using stock bolts again?
Was thinking to just use the stock ones again, and it says to torq to 36ft/lbs. I have a torq wrench so that shouldn't be a problem. Any reason to switch over studs? This is a minor rebuild for a stock turbo and simple bolt on mods until I buy a 205 engine/trans and do my 400hp build. Basically trying to do this work on the cheap, but do it right the first time. :|
2001 Spider (sold)
1990 alltrac (sold)
awdmofo
Postby awdmofo » Wed Jul 13, 2016 4:28 am
I believe we have a winner. Alltracman thanks for the input, Locker your :nono: fired :nono: lol. Redcelica your awesome, and as always underscore you make me :rofl: :rofl: . but thanks though... Now to figure out how to get the intake manifold off, then the T-belt, and then the turbo. should take me a few days of poke around after work to get the head off.
2001 Spider (sold)
1990 alltrac (sold)
awdmofo
Postby Locker » Wed Jul 13, 2016 11:49 am
Sorry you guys are right! I used a 6 point male allen type bit. I wouldn't suggest it unless you're replacing them though...
90 ST185
Locker
Postby awdmofo » Wed Jul 13, 2016 4:37 pm
No worries, I'm learning everyday I work on this guy. I hope to get the timing belt off and maybe Intake manifold off tonight after work, should be fun... :roll:
2001 Spider (sold)
1990 alltrac (sold)
awdmofo
