How to remove the head bolts on a 90 alltrac
Re: How to remove the head bolts on a 90 alltrac
Postby RedCelicaTRD » Wed Jul 13, 2016 10:36 pm
You'll need to measure the head bolts to see if they have stretched and are no longer reusable. I would go with a set of studs, especially if you are going to use a metal head gasket.
Postby awdmofo » Thu Jul 14, 2016 2:31 pm
RedCelicaTRD wrote:You'll need to measure the head bolts to see if they have stretched and are no longer reusable. I would go with a set of studs, especially if you are going to use a metal head gasket.
I guess i'll have to measure them? should the specs be in my Toyota repair manual?
Found this set of 4 sockets that are all 12 point, 6mm 8mm 10mm and 12mm. The 12mm was the correct fit!! only cost me $5.99 :D at Oreillys.
2013 Camaro LS 6-sp (daily)
2005 Yamaha R6 (sold)
2001 Spider (sold)
1990 alltrac (sold)
1991 MR2 turbo x2 (Sold)
awdmofo
