JDM ST165 non-viscous diff
Postby mrfunny107 » Thu Jul 21, 2016 5:10 am
Hey guys, so it's been a long process of getting my 89 ST165 up and running. The motor and trans are out of the car. They are being replaced with a gen1 motor and trans.
Turns out the JDM trans is that of an early ST165. It has several vacuum lines coming out of the end of the transfer case.
Does anyone know where they would go to and how to properly run / set up the lines and wiring???
mrfunny107
Re: JDM ST165 non-viscous diff
Postby Tecker185 » Thu Jul 21, 2016 10:00 pm
Im sure its very similar to what came in my camry alltrac. Id start there
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 GTS Swapped
02 Tacoma TRD Supercharged
15 Corolla S
86 Toyota 1 ton Dually
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby Redrkt01 » Sun Jul 24, 2016 5:12 pm
Mr. Funny, your tranny is called the E50F1....google it and go from there. Also, Tecker's pointer should be useful as well. I'll tell you right now you're missing some parts to make it work....I hope you're able to get it working as opposed to just finding another tranny. That would be pretty sweet.
1989 ST162
1988 ST165 Black
1988 ST165 Red Parts Car
Redrkt01
Postby fussellbug » Sun Jul 24, 2016 6:23 pm
Rather old post referring to the E51F1:
http://www.alltrac.net/phpBB2/viewtopic.php?t=20104
fussellbug
Images: 36
Postby mrfunny107 » Sun Jul 24, 2016 11:56 pm
Can I drive the car without the hoses hooked up???
Looks like I need 2 solenoids.
mrfunny107
Users browsing this forum: Bing [Bot] and 3 guests
