ST185 Carlos Sainz no check engine light won't start
Postby spid1005 » Thu Jul 28, 2016 12:50 pm
Hello, i have a problem maybe someone will help me because i have no ideas. (sorry for bad english). I own a Toyota Celica ST185 Carlos Sainz Limited Edition.
This car starts and run's well but there is 1 BIG problem. Car sometimes doesn't want to start. What happens ?
I can go to the garage start it, it will start normally without problems(Check Engine Light appears when u turn the key to ignition) . I will run it in garage for about ~20minutes, and when i will turn the car off and try to start it again then Check Engine Light does NOT appear on ignition and car won't start.
Here's what happens -> https://www.youtube.com/watch?v=rF-MahNAhIM if im gonna wait 1/2/3 hours and it will cool down then Check Engine Light appears and car starts normally. 1 time i was on a road and car turned off while i was driving. I replaced Fuses / EFI Main Relay, it doesn't solve the problem. I checked error codes when it cooled down connecting Te1 and E1, Check Engine Light was blinking fast i checked what it means, and it means that there are no error codes. Someone can help me what should i do ?
spid1005
Re: ST185 Carlos Sainz no check engine light won't start
Postby audiodjmp77 » Thu Jul 28, 2016 9:22 pm
Is there an aftermarket immobiliser or alarm fitted ? My check engine light does not come on if the car is immobilised
Sent from my Nexus 9
audiodjmp77
Postby spid1005 » Thu Jul 28, 2016 9:24 pm
I checked there is no immobiliser in this car also there isnt' aftermarket one installed.
spid1005
Postby FC Zach » Fri Jul 29, 2016 6:20 am
Mine had similar symptoms like the engine randomly cutting off while driving, starting for one trip but not the other, and waiting a period of time to attempt again and it starts. . .
My fix was the fuel pump relay. The original was toasted, literally, it got so hot that the soldered connection had melted and shorted at times.
I see you mention replacing the "EFI Main Relay", not sure if that's the same relay or not but if not I suggest checking/replacing the fuel pump relay.
Next time this happens, if it leaves you stranded like mine did me, you could bypass the fuel circuit by bridging the "Fp and +B" terminals in the test connector which will keep the pump on to get you home. Here's my "Emergency Help" thread http://www.alltrac.net/phpBB2/viewtopic.php?f=21&t=51010
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby spid1005 » Fri Jul 29, 2016 2:08 pm
Well thanks for advice :). Right now i send car to the mechanic, i hope he will solve the problem. But any suggestions will help.
I added video to YouTube what happens if Check Engine Light doesn't appear, also when Check Engine Light doesn't appear and i turned the key to ignition you can hear this "weird" sound in car(u can listen it at 0:02)-> https://www.youtube.com/watch?v=lakHh5TiHa4, but when Check Engine Light appears this sound doesn't exist. :|. There is another video -> https://www.youtube.com/watch?v=lakHh5TiHa4 after ~10 minutes i managed to run the car as u can see there is a Check Engine Light and there is no this "weird" sound. I give a little gas to the car and it turned off, when i tried to turn it on, there was no Check Engine Light and this "weird" sound appeared. :/
What i also found that if car get's hot it disconnects EFI Main Relay, i left the car on ignition for about 1minute and i was just waiting. Then i heard this "Click" sound that Relays do if they start working and Check Engine Light appeared. I think is something with electricity, like something is broken maybe with cables and when installtion/some wire/cable gets hot it disconnects this relay. Also could it be crankshaft position sensor ? It's not that easy to change it because it's in distributor.
Mechanic said that he goes to 1week vacations, so i need to wait.
spid1005
Postby underscore » Mon Aug 01, 2016 2:58 pm
Either the ECU isn't getting power, or the ECU isn't functioning properly. Given the age of these cars the capacitors in the ECU may be starting to fail when they get hot.
Postby LvX » Thu Aug 04, 2016 2:54 pm
check if the rev needle bounce when you try to start the car, if not is an ecu/distributor problem.
i had similar problem and was the leaking capacitor in the ecu that blew a track.
if the needle bounce than could be a fuel related problem
LvX
Postby spid1005 » Thu Aug 04, 2016 2:57 pm
LvX wrote:check if the rev needle bounce when you try to start the car, if not is an ecu/distributor problem.
Well the problem is that tachometer doesn't work from about 1 year :|.
spid1005
Postby LvX » Thu Aug 04, 2016 2:58 pm
check with an analogic tester on the ignitor or with an oscilloscope.
LvX
Postby spid1005 » Thu Aug 04, 2016 3:25 pm
LvX wrote:check with an analogic tester on the ignitor or with an oscilloscope.
Ok ! Thanks for advice i will test it.
spid1005
Postby spid1005 » Mon Aug 08, 2016 3:43 pm
Today i visited mechanic that repairs my car. And he said he checked everything he could and he can't see the problem. He also said, that it must be some ECU Failure, he's not 100% sure. And here is my question how i can find ECU for this car ? -> ST185 Carlos Sainz Limited Edition (1991)(4WD)(Turbo).
Can someone help me where i can buy some cheap ECU that will 100% work good with this Car. I can't afford to spend X.XXX$ when im not sure if it's ECU problem.
spid1005
Postby LvX » Mon Aug 08, 2016 4:06 pm
Open the ecu, is not difficult at all and check for something visually damaged, then if there is something wrong bring it to some electrycal techinitian to have it repaired. If you don't see nothing wrong check the connector for ground and +12. If everything ok check the distributor.
LvX
Postby spid1005 » Mon Aug 08, 2016 4:21 pm
LvX wrote:Open the ecu, is not difficult at all and check for something visually damaged, then if there is something wrong bring it to some electrycal techinitian to have it repaired. If you don't see nothing wrong check the connector for ground and +12. If everything ok check the distributor.
My car is repairing a mechanic right now. He said he checked ECU and everything was OK, he said he will check it again. I asked in other forum and people said that 19100-88363 Distributor will fit, but i checked and i have 19100-88364 Distributor in my Toyota. Is that true that 19100-88363 will be ok ?
spid1005
Postby audiodjmp77 » Mon Aug 08, 2016 4:41 pm
The ecu is under where the radio is. Where abouts are you, as there is a guy based in the UK that repairs cs ecus. Come to think of it there is a repair guide on the Internet somewhere to replace the faulty capacitors.
Sent from my D5803 using Tapatalk
audiodjmp77
Postby LvX » Mon Aug 08, 2016 4:59 pm
I' ve repaired mine, it's not difficult any tv repair shop can do it, btw i'll check before as a leaking capacitor is easy to see.
I had a burned track with a big black stain on the cover and on the board
LvX
