Grounds
Grounds
Postby mrfunny107 » Wed Aug 03, 2016 12:37 am
Hey guys. Long process of putting my st165 back together. Problem is... I wasn't the one who took it apart... Where exactly do the grounds go on the chassis???
mrfunny107
Re: Grounds
Postby zaluss » Wed Aug 03, 2016 3:45 am
mrfunny107 wrote:Hey guys. Long process of putting my st165 back together. Problem is... I wasn't the one who took it apart... Where exactly do the grounds go on the chassis???
IIRC the factory grounds to the chassis are...
1) Neg battery terminal to mount on drivers side headlight.
2) Alt bracket to passenger strut tower.
Also grounds connected to the starter, transmission, and intake manifold (from the wiring harness). I've upgraded them all to larger gauges and added several places so I can't remember anymore.
zaluss
Re: Grounds
Postby mrfunny107 » Wed Aug 03, 2016 4:10 am
Ok. So I have 4 unknowns.
1. Start ground
2. Transmission ground
3. Inter cooler pump ground
4. Main battery ground
Can I get specifics where they actually go??? Pics would be nice. My transmission ground was cut so I don't even know how long it's suppose to be.
mrfunny107
