1988 All Trac Timing belt parts
Postby hoys » Fri Aug 05, 2016 7:38 pm
Currently looking into replacing the timing belt and all related parts for my 1988 All Trac. I am having a hard time narrowing down what parts are needed for a Gen1 3SGTE as it seems that things like the tensioners changed through the generations.
Does anyone have any experience with what part numbers are correct or accurate pictures of the timing belt setup on a Gen1? The google hasn't helped very much.
Thank you!
hoys
Re: 1988 All Trac Timing belt parts
Postby zaluss » Sat Aug 06, 2016 4:09 pm
Belt 13568-88381
Tensioner 13505-74030
Idler 13503-88380
zaluss
