No Start (I've been searching for 2 weeks)
Re: No Start (I've been searching for 2 weeks)
Postby mrfunny107 » Tue Aug 23, 2016 1:16 am
So for $hits and giggles I bridged the Fp and B on the diagnostics plugs and all I got was Sparks and a hot wire.....
mrfunny107
Postby FC Zach » Tue Aug 23, 2016 3:37 am
Ouch, that's no good! Wonder what's causing the resistance?
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby DonMuscles » Tue Aug 23, 2016 7:52 am
Are you sure you bridged the correct ones?
DonMuscles
Postby DonMuscles » Tue Aug 23, 2016 7:59 am
Oretty sure there are 2 B's.
DonMuscles
Postby DonMuscles » Tue Aug 23, 2016 8:00 am
You need to bridge Fp and B+.
DonMuscles
Postby DonMuscles » Tue Aug 23, 2016 8:03 am
If you are getting loads of resistance, my next guess is the CHANGE THE AFM!!!!
It might seem like a long shot, but the AFM has 2 coils in it!
1 controls electrical signal to the fuel pump, and 1 controls the starter! These can build up resistance over time if not used!
Change the AFM with one that works and then try and start the car. You might have to try the ignition a few times before it starts up.
If I am correct, you can send me something from the USA in the post! :).
DonMuscles
Postby mrfunny107 » Tue Aug 23, 2016 11:09 am
Yeah. It was B+. But still. I would think the AFM would have nothing to do with the car cranking.
mrfunny107
Postby DonMuscles » Tue Aug 23, 2016 12:39 pm
Try it.
DonMuscles
Postby mrfunny107 » Tue Aug 23, 2016 1:40 pm
Find me one. Arnt those hard to come by???
mrfunny107
Postby DonMuscles » Tue Aug 23, 2016 1:43 pm
There is one on ebay, but you need to try one from somebody elses car that is running so you know it works!
DonMuscles
Postby mrfunny107 » Sat Sep 03, 2016 11:11 pm
She cranks!!!!! But still no fuel pump. I checked the diagnostics connector and I was only getting 5V.
Swapped engine harness's. Crossed fingers and she cranked. Do fuel pump resistors go bad???
mrfunny107
Postby DonMuscles » Sat Sep 03, 2016 11:23 pm
What did you try?
DonMuscles
Postby DonMuscles » Sat Sep 03, 2016 11:24 pm
Did you swap the afm?
DonMuscles
Postby mrfunny107 » Sat Sep 03, 2016 11:30 pm
Bought a better conditioned engine harness and swapped. I didn't change AFM because I don't have an extra.
mrfunny107
Postby mrfunny107 » Sun Sep 04, 2016 4:24 am
So... I'm only getting 1.5V at the connector. And 12V at the diagnostics port. I checked my fuel pump resistor... 8ohms and spec is 0.73ohms.....
mrfunny107
