No Start (I've been searching for 2 weeks)
Re: No Start (I've been searching for 2 weeks)
Postby mrfunny107 » Fri Sep 09, 2016 2:41 am
More progress. Besides the fuel pump being 100% shot, I finally got 12V to the fuel pump... But... Only when I crank the car. Any ideas why it still doesn't prime?????
mrfunny107
Postby DonMuscles » Fri Sep 09, 2016 6:02 am
Afm?
DonMuscles
Postby mrfunny107 » Fri Sep 09, 2016 6:06 am
If you got some sort of step by step method of testing the AFM by all means I'm ears. It's just a little scary because of it is the AFM they don't come up for sale often.
mrfunny107
Postby FC Zach » Fri Sep 09, 2016 7:42 am
Do you have a DVOM and service manual? I believe there's step-by-step testing instructions for the AFM. I would check for you but I'm in the process of moving and have all my literature boxed up.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby mrfunny107 » Sat Sep 17, 2016 5:46 pm
Well more progress... I know get 12V to the fuel pump if I jumper the Fp and B in the diagnostics port without the jumper melting...
I finally got around to looking under the rear end of the car for the first time since I got it and I'm not gonna lie.... Its a bit rougher than I expected... Rust through the rockers and bottom rear quarters. Luckily I stumbled upon a post here about fixmyrust.com and they sell the panels!!!!!!!!
Entire fuel system was shot. If I could figure out how to post pics I would but its a little different than posting pics on newcelica. So I ordered up a 10gal fuel cell and all the fixin's.
It is a good possibility of the car firing up for the first time in 11 years next Sunday.
mrfunny107
Postby Rick89GTS » Sat Jan 07, 2017 2:12 am
That fixmyrust.com is a nice resource. Did you ever get your car running?
Rick89GTS
Postby alltracman78 » Sat Jan 07, 2017 1:06 pm
mrfunny107 wrote:Any ideas why it still doesn't prime?????
It's not going to; Toyotas don't "prime". They only run when the engine is starting or running.
Postby mrfunny107 » Sat Jan 07, 2017 1:31 pm
mrfunny107
