Which brand of reman power steering pump?
Postby r-town » Thu Oct 06, 2016 11:07 pm
So I cleaned the PS pump and oil pump area to track leaks. After running the car for several mins, the oil pump is dry/clean and it looks like the power steering is going (slow leak into cv axle which creates a mess). I found a re-manufactured pump at rockauto, but which brand is good for reman pumps? or do you guy recommend rebuilding the current pump?
r-town
Re: Which brand of reman power steering pump?
Postby yyonline » Fri Oct 07, 2016 5:32 am
The only brand I've had any luck with long term has been Maval, but rockauto doesn't sell those and they're expensive.
yyonline
Postby zaluss » Fri Oct 07, 2016 12:09 pm
Significantly more expensive but will likely last you a lifetime.
http://www.gt4-play.co.uk/catalog/produ ... cts_id/152
zaluss
Users browsing this forum: Nickzendar and 1 guest
