Head pulling question on ST165
Postby Killtodie » Fri Nov 18, 2016 9:13 pm
My ST165 has been parked at my parents house for over a year now, it blew a headgasket as I drove to visit them, and I left it there for now.
I finally have the time to pull the head, and see what's up.
A few questions.
-What is that special tool to remove the head bolts?
-Are the head bolts torque to yield, or are they reusable?
-Do I need to bring jack, and jack stands? Anything I need to get form under?
I am gonna pack whatever tools I think I need, and pull the head.
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Re: Head pulling question on ST165
Postby zaluss » Fri Nov 18, 2016 10:09 pm
Head bolts are 12mm triple squared. https://www.amazon.com/Capri-Tools-3006 ... 61688SZXQ4
Head bolts are absolutely not reusable. Get replacements or ARP head studs.
The biggest PITA is the intake manifold removal. Alternatively you could pull the head with the intake manifold on but that is difficult to remove.
zaluss
Postby alltracman78 » Sat Nov 19, 2016 2:17 am
Per Toyota, the head bolts are reusable; as long as they're not stretched.
If you're trying to double the stock power I wouldn't reuse them [I would suggest head studs then anyways]. For a stock rebuild I don't see the harm in reusing them.
As far as that tool, the link takes you to a 3/8" drive socket. I would suggest a 1/2 drive socket. Easier to put the correct torque with a 1/2 drive bar vs a 3/8 bar.
Postby Killtodie » Sat Nov 19, 2016 3:00 pm
zaluss wrote:The biggest PITA is the intake manifold removal. Alternatively you could pull the head with the intake manifold on but that is difficult to remove.
Why? Is it cause its braced from the back?
Killtodie
