Where does the Power Steering Wire plug into the unit?!?
Postby Justin311 » Thu Mar 02, 2017 12:46 am
Ok doing a Gen4 swap and put a reman Alltrac PS pump on the Gen4 motor. I wasn't the one who pulled the original pump off. My wiring guy tells me the green wire/black plug in the pic below is for PS. However my pump doesn't have any sensors on it - just the 2 port vacuum switch. Can anybody help? This is holding me up from installing the motor!
Justin311
Re: Where does the Power Steering Wire plug into the unit?!?
Postby MrDB » Thu Mar 02, 2017 7:23 am
Its a mechanical pump it has no connecor.
MrDB
Postby Justin311 » Thu Mar 02, 2017 2:12 pm
I figured it out. When using a gen 4 ecu you must add the sensor from the Caldina pump. Luckily it swaps over easily - it is sandwiched by an adaptor at the banjo. I'll snap a picture in case others run into this.
Justin311
Users browsing this forum: Baidu [Spider] and 2 guests
