Which heater hoses from Oreilleys? Descriptions confusing!
Postby Justin311 » Thu Mar 02, 2017 5:41 pm
Attached is what Oreilley's shows available. I need the hose from the heater core outlet (nipple on firewall) to the hard water pipe on the engine.
The picture of item# 18922 ($16.99 hose below) seems closest to what I pulled off, however the description says "heater to valve", while the valve is on the other hose that goes to the water neck. Anybody have a reference to which is the correct hose? I have to special order them so going down to the store and matching up is not an option :(
Justin311
Re: Which heater hoses from Oreilleys? Descriptions confusi
Postby yyonline » Fri Mar 03, 2017 8:28 am
GATES 18715 goes to the heater core pipe without the valve.
yyonline
Postby yyonline » Fri Mar 03, 2017 8:30 am
I have the Gates hose and the discontinued Toyota hose (87245-2B560) both in hand, so I can say for sure that's the one you want.
yyonline
Postby Justin311 » Fri Mar 03, 2017 4:37 pm
Thanks guys!
Justin311
Postby Justin311 » Mon Mar 06, 2017 6:36 pm
The 18715 fit perfectly. Thanks folks!
Justin311
