E154F Transmission Dumb Question
Postby discoinferno218 » Thu Apr 27, 2017 11:35 pm
Ok this is probably a dumb question but I cannot figure out what this piece is.. It is off the passenger side by the mount. It looks like there was a nipple or valve of some kind that broke off. Any idea what this piece is? And if I need to replace it?Image
discoinferno218
Re: E154F Transmission Dumb Question
Postby alltracman78 » Thu Apr 27, 2017 11:47 pm
It's a breather/vent. You probably should, that hole is letting [small] amounts of dirt in.
Postby discoinferno218 » Thu Apr 27, 2017 11:51 pm
alltracman78 wrote:It's a breather/vent. You probably should, that hole is letting [small] amounts of dirt in.
It is currently out and not running so that isn't an issue. Thank you very much!
Ok one more dumb question. Is the housing made of cast aluminium? Or what?
discoinferno218
