CT27 turbo rebuild, turbo rebuild services or rebuilt turbo?
Postby EvilStig » Tue Sep 19, 2017 1:45 am
I have a CT27 in my ST185 and it's slinging oil. I assume it's going to need a rebuild. I can buy the kit to rebuild it but am unsure if I should attempt it myself, or, if not, where I could take it to get it rebuilt? Does anyone still build CT27 turbos?
EvilStig
Re: CT27 turbo rebuild, turbo rebuild services or rebuilt tu
Postby FC Zach » Tue Sep 19, 2017 3:06 am
These guys?
https://majesticturbo.com/
Maybe ATS Racing can, they built the "CT27".
http://www.atsracing.net/Parts/Index/CT27
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby EvilStig » Tue Sep 19, 2017 3:50 am
Thanks! didn't know about ATS, very good to know they're still around, I'll drop them a line.
EvilStig
Postby Gt4grey » Tue Sep 19, 2017 8:22 pm
I would'nt recommend rebuilding the turbo yourself, deffo needs a specialist with the proper equipment to do a long lasting job.
Gt4grey
Postby EvilStig » Wed Sep 20, 2017 12:06 am
Ok thanks all, I got in touch with ATS and they'll do the rebuild for $425 assuming it doesn't need a turbine or housing (it shouldn't) also asking them to tag on the ceramic coating for a little extra.
EvilStig
Postby FC Zach » Wed Sep 20, 2017 3:16 am
I just sent them an email to see if they'd modify my turbo, I like the idea of having more power and keeping things stock bolt-on. How do you like the CT27? Will I need a stand-alone ECU or will the stock support the added power?
FC Zach
Images: 9
Postby lalojamesliz1 » Wed Sep 20, 2017 3:57 am
FC Zach wrote:I just sent them an email to see if they'd modify my turbo, I like the idea of having more power and keeping things stock bolt-on. How do you like the CT27? Will I need a stand-alone ECU or will the stock support the added power?
I've always seen they are very similar to a ct20b power wise
91 Celica all-trac gen3 swap
87 toy 5speed long bed
69 mustang
08 sequoia
14 avalon
and a 2 car garage :shoots:
lalojamesliz1
Postby EvilStig » Wed Sep 20, 2017 4:29 am
stock ecu is enough, but needs EBC and a fuel cutoff bypass to use the extra boost. When I bought the car, it was lacking these mods, so it would boost up to 12-15PSI and then hit fuel cutoff. It also had other issues though, vacuum leaks and a jury-rigged recirculator... I'm cutting that out and replacing it with a proper BOV and adding in the EBC and cutoff bypass before I button her back up.
EvilStig
Postby FC Zach » Wed Sep 20, 2017 4:35 am
Good to know, thanks! Oddly, I have gone to and over 12psi with my 26 and haven't hit fuel cut and to my knowledge I don't have a bypass for this. . I do have a blowoff valve and an adjustable billet wastegate actuator (12lb spring).
FC Zach
Images: 9
Postby underscore » Wed Sep 20, 2017 5:04 am
Fuel cutoff is 14.7psi on 165's and 185's, excluding the RC/CS/GrpA. A BOV just makes a pretty sound but a boost controller or adjustable wastegate will help things. Personally I like my EBC because it can ut the boost back to the stock wastegate pressure if it detects a problem.
Postby FC Zach » Wed Sep 20, 2017 5:10 am
underscore wrote:Fuel cutoff is 14.7psi on 165's and 185's. . .
Good to know.
underscore wrote:A BOV just makes a pretty sound
Ha Ha, yeah true and I love it!
underscore wrote:Personally I like my EBC because it can ut the boost back to the stock wastegate pressure if it detects a problem.
I like that too, I plan on installing one. Which one do you have?
FC Zach
Images: 9
Postby EvilStig » Wed Sep 20, 2017 6:07 pm
I'm installing one to help reduce stress on the engine and manifold. Too much boost when letting off on the gas is bad. And I'm having issues with a lean condition as it is.
EvilStig
Postby underscore » Wed Sep 20, 2017 8:16 pm
FC Zach wrote:Ha Ha, yeah true and I love it!
Me too, that's why I have one haha.
FC Zach wrote:I like that too, I plan on installing one. Which one do you have?
I've got the Innovate SCG-1. It's a boost gauge, boost controller and wideband all in one. The upside of that is that it can cut boost if it detects a spike in boost pressure or that you're running too lean. It's takes a bit more work to set up than a "point and shoot" boost controller but I like the added protection.
EvilStig wrote:I'm installing one to help reduce stress on the engine and manifold. Too much boost when letting off on the gas is bad. And I'm having issues with a lean condition as it is.
Pressures slightly above the stock fuel cut shouldn't be a risk to the manifold or anything else. If you're running lean I'd fix the actual problem instead of trying to use a BOV as some kind of bandaid.
Postby EvilStig » Wed Sep 20, 2017 9:06 pm
underscore wrote:Pressures slightly above the stock fuel cut shouldn't be a risk to the manifold or anything else. If you're running lean I'd fix the actual problem instead of trying to use a BOV as some kind of bandaid.
Oh of course I'm fixing the problem... but I also over-engineer everything so it can never fail again
EvilStig
Postby FC Zach » Thu Sep 21, 2017 6:39 am
underscore wrote:I've got the Innovate SCG-1. It's a boost gauge, boost controller and wideband all in one. The upside of that is that it can cut boost if it detects a spike in boost pressure or that you're running too lean. It's takes a bit more work to set up than a "point and shoot" boost controller but I like the added protection.
Man that is nice! I haven't seen this one, I sure am happy I have now, thanks! I've always liked the Innovate A/F products, it's a big plus that they've crammed all that in one gauge. Super convenient!
FC Zach
Images: 9
