Replacing Timing Cover
Postby Aaron » Thu Nov 02, 2017 1:52 am
Hi, guys. Probably a simple question, but what's the best way to install the upper timing cover with the engine already in the car? It doesn't seem like it can be squeezed in without dropping the motor in some way.
__________
Aaron
1992 ST185
1989 AE95 Wagon
Aaron
Re: Replacing Timing Cover
Postby FC Zach » Thu Nov 02, 2017 5:08 am
It's doable. A tight squeeze but doable.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby FC Zach » Thu Nov 02, 2017 5:13 am
1/4" drive ratchet, extension and socket as well as ratcheting wrench.
FC Zach
Images: 9
Postby GT4_DRED » Thu Nov 02, 2017 4:57 pm
drop the two nuts that hold the pass. motor mount to the engine (not the chassis) and jack that side of the motor up. You should have enough clearance; works for me.
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Postby Il_Barone » Wed Dec 06, 2017 10:39 am
Will you install the clear cover?
Il_Barone
Postby alltracman78 » Wed Dec 06, 2017 2:06 pm
GT4_DRED wrote:drop the two nuts that hold the pass. motor mount to the engine (not the chassis) and jack that side of the motor up. You should have enough clearance; works for me.
This.
Also, if you pop out the Pwr steering reservoir you can lift it and the lines a little and gain some more room.
