Can't find what's loose in front suspension
Re: Can't find what's loose in front suspension
Postby ___Scott___ » Sat Nov 11, 2017 4:01 pm
lalojamesliz1 wrote:Is there a standard bushing replacement available I just can't find?
I couldn't find any for my ST165. I discovered that I could buy the whole lower control arm pretty cheap from RockAuto which includes the rubber bushing. I bought a pair of them and they were better than the old bushings, but not a lot better.
I'll do a write-up on how I made my poly bushings for people like me who just want to experiment with the DIY approach.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby underscore » Sat Nov 11, 2017 4:43 pm
Whiteline, GT4-Racing and someone else all make poly bushings for the front and rear. If the bushings are shot new LCAs will give more of a stock right and be a faster job to replace.
Postby lalojamesliz1 » Sat Nov 11, 2017 6:37 pm
Unfortunately i wasnt able to find replacement control arms, just the bushings. I guess that's my only option. Wtf man :shoots:
91 Celica all-trac gen3 swap
87 toy 5speed long bed
69 mustang
08 sequoia
14 avalon
and a 2 car garage :shoots:
lalojamesliz1
Postby lalojamesliz1 » Sat Nov 11, 2017 6:40 pm
underscore wrote:Whiteline, GT4-Racing and someone else all make poly bushings for the front and rear. If the bushings are shot new LCAs will give more of a stock right and be a faster job to replace.
Have you seen new lca's for sale?
69 mustang
08 sequoia
14 avalon
lalojamesliz1
Postby ___Scott___ » Sat Nov 11, 2017 7:40 pm
lalojamesliz1 wrote:Have you seen new lca's for sale?
I just assumed they would be available for the ST185 as well as my ST165. A quick look at RockAuto didn't show any though.
Hot off the press, the write-up on DIY bushings is here if you are interested:
viewtopic.php?f=49&t=52521
Scott
SONY
___Scott___
Postby lalojamesliz1 » Sun Nov 12, 2017 7:40 pm
Nice job man!
69 mustang
08 sequoia
14 avalon
lalojamesliz1
Postby lalojamesliz1 » Thu Feb 01, 2018 12:19 am
Just wanted to give a update since lots of people were nice enough to help me with needed info.
I just received and installed whiteline poly swaybar bushings for the and rear that I bought from summit racing.
The front suspension clunk when backing out of my driveway and the dreaded rear clunk are gone :D
I also ordered whiteline front control arm bushings but since I no longer have the suspension noise I might return them. I'm tempted to keep them though because of the age their age and they are currently covered in oil from a previous leak. I don't have a multi ton press and I was going to use a balljoint press but it sounds like a PITA
69 mustang
08 sequoia
14 avalon
lalojamesliz1
Users browsing this forum: buffalohunter7321, Google [Bot], Google Adsense [Bot] and 2 guests
