OIL COOLER GASKET/O RING DISCONTINUED, ALTERNATIVE?
Postby Anoo21 » Wed Nov 15, 2017 10:43 pm
I am replacing somethings in the cooler area and had to take the hard lines that connect to the oil cooler on the 3sgte.
Part # 15785-88380, obviously it is discontinued. Does anyone know or have an alternative? It looks like a crush washer. I will post a picture when I get home. Anything will help, I really do not know if I can reuse the old one. thanks guys
The link is to the image, I will try to post a picture of the actual washer.
https://photos.app.goo.gl/2MfaYHuvQiNWIa6r2
Anoo21
Re: OIL COOLER GASKET/O RING DISCONTINUED, ALTERNATIVE?
Postby fussellbug » Fri Nov 17, 2017 8:32 pm
If you get accurate measurements on the crush washers, you can look for a match online. Amazon sells sets of various size copper crush washers that may include what you need. Like this one:
https://www.amazon.com/dp/B0743BHJ9X/ref=sspa_dk_detail_1?psc=1
If you're in a hurry or can't get a good measurement, take a used crush washer and banjo bolt to your local auto parts store and ask the to help you find a close match.
fussellbug
Images: 36
Postby JRWperformance » Wed Nov 22, 2017 11:06 pm
If its a copper crush washer, and it is still in OK shape, you can anneal the copper. Do it by getting the washer red hot with a propane torch and quenching it in cold water. The copper will become super soft again. I do this all the time and it woks great.
88 Celica Alltrac
78 Honda GL1000
04 Volvo S60R (Now Dead)
91 VW Jetta Turbo Diesel
JRWperformance
