Pulling the engine for this and that
Re: Pulling the engine for this and that
Postby FC Zach » Thu Dec 21, 2017 4:06 am
lalojamesliz1 wrote:Do you have to worry about the timing cover or gears or anything on that side when using the MSM?
I didn't because my upper timing cover was already cracked and I planned to replace it anyways however with that said it wasn't like I had 100% of the weight centered on that area. . . regardless I'd cushion the area with scrap carpet/towels (I can't remember what I used).
lalojamesliz1 wrote:What bolt holes do you use to secure a chain to the trans when doing the MSM?
I don't remember, I just picked two spots that evenly distributed the weight. I may have added a ratchet strap to a third spot to prevent the trans from rotating once released from the engine.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby lalojamesliz1 » Thu Dec 21, 2017 6:50 am
So will the valvoline mp grease I have be fine or should I look for some white lithium or synthetic?
Thank you everyone for your help.
91 Celica all-trac gen3 swap
87 toy 5speed long bed
69 mustang
08 sequoia
14 avalon
and a 2 car garage :shoots:
lalojamesliz1
Postby FC Zach » Thu Dec 21, 2017 8:43 am
lalojamesliz1 wrote:So will the valvoline mp grease I have be fine. .
That's exactly what I used.
FC Zach
Images: 9
Postby lalojamesliz1 » Thu Dec 21, 2017 2:56 pm
Great minds think alike 8)
69 mustang
08 sequoia
14 avalon
lalojamesliz1
