hoses from hell
hoses from hell
Postby twoFOURS » Mon Aug 09, 2004 1:22 am
What are the part numbers for hoses from hell?
Any help much appreciated.
twoFOURS
90 Alltrac black
91? GT4 RC red
twoFOURS
Postby Gary » Mon Aug 09, 2004 3:12 am
http://www.mrtwo.net/mr2modproject/service/hfh/hfh.htm
Not sure if the part number is correct. Check with Toyota.
93 ST185
Gary
Postby alltrac.net » Mon Aug 09, 2004 4:30 am
I should note for anyone trying to do this mission in the middle of the night that I was able to replace the HFH using only parts found at kragen. Total cost $11. This included:
4" piece of hose in the right thickness
2 very small hose clamps
1 package of "muffler repair" tape to keep it from getting hot
Before I installed the hose I completely covered it in the muffler repair tape for heat rejection. Almost a year later the hose is holding up. In fact the car is a friend of mine, his daughter's car and it's daily driven.
This isn't the ideal solution but it is an option. I still suggest buying proper parts from Toyota.
alltrac.net
Site Admin
Postby Felix » Mon Aug 09, 2004 4:36 am
I never got into detail about the hfh on the old server...
what's is the hfh's main objective...i know it is a simple part, but getting to it and replacing it is a bitch. I don't wnat to overlook any potential problems while tuning up and doing maintenance on the AT
1992 Celica ST 5Speed "Midnite Black"
1991 MR-2 GT 5Speed T-Tops "Arrest Me Red"
2005 Scion tC 5Speedd Flint Mica Gray "MY XTC"
-We Miss You- 1990 Celica All-Trac Turbo (G/F's) (Sold)
Felix
Postby mofoparrot » Mon Aug 09, 2004 4:42 am
I posted the part numbers for it in the part's section. I just ordered them.
1990 ST185 sold
West Hartford, CT
mofoparrot
Postby Gary » Mon Aug 09, 2004 4:57 am
Felix wrote:I never got into detail about the hfh on the old server...
Read the link I post above. HFH is just a coolant hose that use to cool the oil at the oil cooler. Parts numbers on that link match what mofoparrot posted in the part number section.
93 ST185
Gary
Postby gtfourdreams » Mon Aug 09, 2004 5:14 am
if you still need them, i can get them from my order list tomorrow. i like using OEM ones, not the NAPA crap because if you bend the straight ones at such a sharp angle they deteriorate faster. (from my experience) i also use OEM clamps, but thats a personal taste thing.
gtfourdreams
Re: hoses from hell
Postby billprice » Mon Aug 09, 2004 12:29 pm
twoFOURS wrote:What are the part numbers for hoses from hell?
Hose from Hell#1 16283-88381
Hose from Hell#2 16282-88380
'07 GS350 AWD
'09 Toro Z5030 ZTR 23hp of lawnmowing fun
billprice
Postby Stubble » Tue Aug 10, 2004 2:44 am
Robert,
If your Kragen fix worked, either you are lucky or I'm unlucky. When I was first learning to repair my car, I tackled this job and didn't use the OEM hose, just a hose from Napa or something. I wrapped it in insulation used for aircraft exhaust. Two months later, the hose had disintegrated and I got to do the job again - this time with the correct Toyota part ($5 if I remember).
I strongly recommend going with the OEM hoses.
Brady Ryall
1990 ST185 Red - parts
1990 ST185 Black
1999 Miata
2008 A3 Quattro S-line
Stubble
I have both hoses from hell, used for 100miles, make offer..
Postby acylon » Tue Aug 10, 2004 12:25 pm
I went to an external oil cooler. These are factory Toyota bought a couple months ago, installed, used for 100miles, removed carefully as they were not cheap. Make me an offer :lol:
James Unger
'88 ST175 Rally Car (ENZO)
http://www.pregrid.com/acylon/
acylon
Postby mototebok » Tue Aug 10, 2004 1:14 pm
Uhh... the hoses are cheap... :roll:
-Adam
'88 Alltrac .... Got a shiny new turbo
'94 RX7 .... Other money black hole
'00 ZX6R .... Lime Green Speed Machine
mototebok
Postby acylon » Tue Aug 10, 2004 5:12 pm
Nothing from toyota is cheap.
James Unger
acylon
Postby Dano » Wed Aug 11, 2004 1:40 am
In March 2003 Toyota replaced engine oil cooler bypass hoses on my 1993 MR2 but only listed part #16283-88381 for $5.30 CDN. They also made a few mistakes on this bill like charging me twice for a distributor cap.
However in June 2003 the same dealership, on my 1988 Celica turbo 4wd, charged me for:
"Water by-pass hose" #16283-88380 $56 CDN
"By-pass hose" #16295-88380 $34.80 CDN
"By-pass hose" #16282-88380 $17.30 CDN
twoFOURS: the HFH parts# you need will likely depend on which generation of the 3sgte engine you have.
'88 red Celica Turbo 4wd--for sale $1500
'93 yellow MR2 Turbo
'91 red Dodge Turbo diesel 4x4, with pop-up custom camper
'97 white 4Runner 4x4 SR5 "creampuff"
Dano
Postby Gary » Wed Aug 11, 2004 2:59 am
acylon wrote:Nothing from toyota is cheap.
Well, Scion is one, another is the oil filter ($6) :mrgreen:
93 ST185
Gary
