question-spec clutch install on 165
Postby Austen_gt4 » Mon Aug 09, 2004 1:42 am
ok has anyone ever installed a spec clutch on a 165.. it came with a piolit bearing and i was wondering if it was used in the install.. i'm having probs.. put the bearing in and it seems to be holding the tranny up from going all the way through the fly wheel and into the oppening.. it seems to be hitting the bearing, and pinching it ( the shaft/spline ) and not letting the motor spin freely.. i'm stumped as wether i'm to use it or not..
Thanks
Austen
2006-DURAMAX RaPeVaN
2008-RUCKUS
2004-IS300
1993-MR2T X 2
1992-GT4
1991-SPEC MIATA
LOTUS 7 (in progress)
Austen_gt4
Postby smc252 » Mon Aug 09, 2004 10:26 pm
The pilot bearing is not needed, I have a Spec Carbon-Kevlar and it works great so far.
1988 All-Trac
(Rotting away, fiending for a tranny.)
1986 Celica GTS
(GT3071R forced 3s-gte + autronic smc)
smc252
Postby Austen_gt4 » Tue Aug 10, 2004 1:24 am
yeah dude thanks i got it figured out.. just wanted to make sure tho.. didn't want to do it wrong and find out later...
2008-RUCKUS
2004-IS300
1993-MR2T X 2
1992-GT4
1991-SPEC MIATA
Austen_gt4
