Please name your brand of transmission fluid
Postby QIK_GT4 » Sat May 21, 2005 5:20 am
Since im getting a crunch when changing gears! I thought I might try a tranny oil change first b4 I do anything more expensive lol...
So... what type or brand do you use?
Is Synchromesh that good? and what brand is Synchromesh? ("googled" it and got too many results)
What about redline? (quite an expensive product over here in OZ!)
Anyone heard of or uses "Castrol Multitrax"? (This is only brand we carry at the place I work)
The Car:Black JDM 1990 ST185
The Mods: Whiteline Rear-sway-bar, K&N Panel, 3" Dump, HKS BOV, 2" Boost Gauge, Garret TMIC, TWM Short Shifter, Mirror Tints
QIK_GT4
Postby applor » Sat May 21, 2005 5:24 am
have you tried shifting a bit slower?
AWD cars need longer in shifts.
applor
Postby maroon_185 » Sat May 21, 2005 5:26 am
I gots pennzoil synchromesh, solved my 2nd gear grind problem.
Chris Fowler
1990 maroon 185 (rc swapped)
1991 red mr2 (3s swap coming soon) Dads
maroon_185
Postby rightrac » Sat May 21, 2005 5:27 am
pennezoil makes a synchromesh that is about half as expensive as the GM synchromesh. friend of mine uses it and loves it.
rightrac
Postby QIK_GT4 » Sat May 21, 2005 5:29 am
applor wrote:have you tried shifting a bit slower?
well its not like ive tried ripping the car and quick shifting the heck out of it remember the water pump is borken... :cry: :cry:
so i've only been driving quite slowly... and fully engaging the clutch b4 i shift..
QIK_GT4
Postby Stubble » Sat May 21, 2005 11:33 pm
Brady Ryall
1990 ST185 Red - parts
1990 ST185 Black
1999 Miata
2008 A3 Quattro S-line
Stubble
Postby gtfourdreams » Wed May 25, 2005 3:49 am
I used Redline. it sucks. only good after it warms up... and then it isnt even that good. have it in my MR2 too, also sucks. same problems...
Red 86 Supra MA60
Grey 88 Alltrac ST165
Black 92 Alltrac ST185
Red 93 MR2 SW20
Minneapolis, MN
gtfourdreams
Postby four twenty » Wed May 25, 2005 6:19 am
Yeah, I agree that their tranny fluid is over rated for our cars. I've tried their ATF and their manual tranny fluids and they both yielded really notchy shifting.
I switched over to their lightweight shockproof gear oil in my tranny and differential and it's shifting much better now. I haven't tried Penzoil Synchromesh but people seem to be having pleasing results.
Brent
1989 ST165
Hermosa Beach, CA
four twenty
Postby Stubble » Wed May 25, 2005 3:55 pm
I'm on Pennzoil's 80W-90 oil, GL-5 rated. It hasn't helped with the shifting. This is even on a rebuilt tranny (5000km). Still, I'm hesitant to try Synchromesh - not rated for hypoid gears (GL-5 is), and not sure how our viscous coupling will react with it.
Brady Ryall
1990 ST185 Black
1999 Miata
Stubble
Postby acylon » Wed May 25, 2005 5:44 pm
maroon_185 wrote:I gots pennzoil synchromesh, solved my 2nd gear grind problem.
Ditto
James Unger
'88 ST175 Rally Car (ENZO)
http://www.pregrid.com/acylon/
acylon
Postby silence » Wed May 25, 2005 5:47 pm
Can you all tell me why you thing redline sucks...give me reasons...as i have a rebuilt tranny that I was getting ready to put redline fluid in...I do not want to put the synchromesh in it because it is not gl5 compatible...any other suggestions?
06 WRX, 90 Celica Alltrac & 88 BMW TURBO 325is
http://www.youtube.com/watch?v=Ei5P9LfLRdg
silence
Postby ChrisD » Wed May 25, 2005 6:01 pm
I use Redline. No complaints. :shrug:
1988 ST165
1994 ST205 WRC
ChrisD
Postby OlyST185 » Wed May 25, 2005 8:11 pm
i heard that the GM synchromesh oil is very good for shifting but i heard it reduce the life of the gear, any thoughs on that?
-Oly (Montreal)
3SGTE'S POWER, 4WD SUPREMACY
[img]http://olyst185.multimania.com/turbo4wd.jpg[/img]
-ST185 1990 Black. RC/CS Conv.
OlyST185
Postby goldfish » Thu May 26, 2005 2:04 am
I use Amsoil. I'm a full Amsoil believer. I had some grinding...put in the new stuff and haven't had any problems since (1.5 years ago). I've got 160k on it now. I put it in the Tranny and the rear diff. http://www.amsoil.com/storefront/fgr.aspx
I just pulled the engine and will be buying more of the same to put it in when i put it all back together. I use Amsoil everything in my car now. Love it! I go 6k miles between changes and the oil still feels great. They make high quality filters and I will be putting on their remote filtration kit with a fine filter when I put the car back together.
https://www.amsoil.com/storefront/bf.aspx
For NA cars, they have an oil that they guarantee for 35k miles/1 year. My father put that in his new Avalon and left it in for 14 months and 29000 miles. He has the fine filter kit on. After the 14 months, the oil wasn't black - just a dark brown and it still felt like the day he put it in. I dont know if you have ever felt a crappy oil after long use...it feels like water. This stuff still felt like oil. It has a high boiling point. They make a turbo formulated version for motor oil.
https://www.amsoil.com/storefront/atm.aspx
Okay, i guess i got a bit off topic - but needless to say, i like them and dont plan to change. If you know someone with a distributor account (like myself) you can get it drop shipped to you in usually 2 days - at a decent discount to what is listed on that site. i got the distributor account because i buy enough stuff to save money that way. i dont actually distribute, but i do favors for friends and family...
David G.
'91 ST185
goldfish
Postby goldfish » Thu May 26, 2005 2:11 am
cool - i just found this:
http://www.amsoil.com/scripts/runisa.dl ... TA,I,92415
they have a list of stuff for most cars...cool.
David G.
'91 ST185
goldfish
