Windshield washer pump
Postby Stubble » Sun Aug 29, 2004 8:12 pm
I'm not getting any fluid spray when I turn on either the front or rear sprayer. With the engine off, I don't hear any pump sounds, but I'm not sure if it would be loud enough to hear. The wipers work fine, so I don't think it's the fuse (looking at the wiring diagram, it shares the same fuse).
Does anyone know of a way to test just the pump itself? How hard is it to remove the pump? I can't even see the pump, as I think it is hidden behind the fender inner liner. Any advice would be appreciated.
Brady Ryall
1990 ST185 Red - parts
1990 ST185 Black
1999 Miata
2008 A3 Quattro S-line
Stubble
Postby Gary » Mon Aug 30, 2004 5:26 am
The washer motor is next to the washer bottle.
There is a plug with 3 terminals.
Hook them up with a battery
The middle one is +
The others are - , one side is for the front and another is for the rear.
Hook it one side at a time, (+ and - )and see if the motor's working.
Test must be done within 20 seconds otherwise, you will burn the coil.
93 ST185
Gary
Postby Stubble » Mon Aug 30, 2004 3:36 pm
Gary,
Is the pump and connector visible from the top of the engine? I can see a cylindrical gray connector between the washer reservoir and the fender. I don't see the pump - all I see in that area is the ABS controller.
Brady Ryall
1990 ST185 Black
1999 Miata
Stubble
Postby alltracman78 » Mon Aug 30, 2004 10:32 pm
Pump is on the bottom of the reservior. Remove the front of the pass side fender cover. You will see the reservior and the pump (it's black, with hoses coming off it).
Postby Gary » Mon Aug 30, 2004 10:38 pm
Look like this:
93 ST185
Gary
Postby smoothray » Tue Aug 31, 2004 2:38 am
hey stubble, can you tell me the outcome...if it was bad afterall, i'm having the same exact problem. i was wondering the likelyhood of a washer pump even going out?? thanks, gary MD
smoothray
Postby Stubble » Tue Aug 31, 2004 3:06 am
I'm going to try to get to it Wednesday, I'll let you know.
Brady Ryall
1990 ST185 Black
1999 Miata
Stubble
Postby Rick89GTS » Tue Aug 31, 2004 2:59 pm
smoothray wrote:.........i'm wondering the likelyhood of a washer pump even going out??.......
It CAN and DOES happen...
Rick89GTS
Postby Stubble » Thu Sep 02, 2004 6:41 pm
Pump is FUBAR. :(
Off to the parts store to try to find another...
Brady Ryall
1990 ST185 Black
1999 Miata
Stubble
Postby Stubble » Fri Sep 03, 2004 1:00 am
:shoots: So NAPA and Canadian Tire don't stock the correct washer pump. Their books list two separate pumps for '90-93 Celicas - one each for the front and rear washers. Ours has both in the same pump body. I'm going to check some wreckers for base Celica pumps. Failing that, OEM!
Smoothray, it's easy to get in there (remove the right undercover and half the right fender liner). The tough part is getting alligator clips on the 3 pins, if you test it without removing it. If you drain the reservoir, the pump just pulls straight out.
Brady Ryall
1990 ST185 Black
1999 Miata
Stubble
Re: Windshield washer pump
Postby soarer.jzz30 » Tue Apr 15, 2014 9:24 pm
if you need a newer unit, the 2000+ celica gts has a denso direction selectable unit that is easier to find and fits. The oem maruko unit is near impossible to find and dies easily especially if you use both switches at once.
soarer.jzz30
Postby underscore » Tue Apr 15, 2014 9:28 pm
How the hell did you find a 10 year old thread?
Postby soarer.jzz30 » Tue Apr 15, 2014 10:16 pm
I was searching for a new washer pump on google. Ever since the forum started using Google i find old threads all the time. A decade passes and i dig it up idk.
soarer.jzz30
Postby Rick89GTS » Wed Apr 16, 2014 2:16 am
^A world record!! :wink:
Rick89GTS
Postby underscore » Wed Apr 16, 2014 2:53 pm
It probably is, 10 years is nearly half the age of some of our cars!
