mototebok
New member
Well... this is more for anyone else's benefit than anything, sence I already discovered the source and cause...but let's start from the beginning.
So I have this coolant leak, horribly fast, like a steady stream of water when the cars cold or warm. Primary dripping was comming down from the back of the oil pan, firewall side. however... there was also dripping all around the engine. "Uh oh" I immediate thought, blown HG. After getting the shrounds off the bottom, I discovered a steady stream of water flow comming from the exhaust side of the oil pan, right on the corner by the crank pulley.
At this point I felt better because it was one source, and I made the mistake of thinking it was the thermostat housing or hose. I got the thermostat out... and replaced it with a new stant all metal one... only to notice that was not where it was comming from. There seemed to be no coolant on the block behind the thermostat housing and the bypass tube. At this point I needed to take off stuff to see where this coolant was comming from.
The a/c system needed to be charged anyways, so I just said screw it and removed everything, and I mean everything related to the a/c under the hood. 5 hours later the compressor was out, the a/c lines, the condenser, drier, and while I was at it... the cruise control (Wow, alot heavier than I expected) and that silly loop for the power steering fluid.
Here's the stuff that came out that's never going back in:
OK, so now I can see where the coolant is comming from... this little hole on the water pump housing:
Sence this board was down... I was posting on the mr2 board... trying to figure out if this hole is supposed to have a plug in it or something. After getting no useful responses, I started the journey to pull the water pump.
I'm really wondering how they assembled all this stuff into the engine bay, because first off, I had to pull the engine mount to get to a couple bolts for the timing belt covers, but to pull the engine mount I had to remove the power steering reservior. I then proceeded to use the old jam the wrench against the axle and use the starter trick to break free the crank pulley bolt. Fashioned myself a makeshift pulley puller using two c-clamps, a lug nut key, and a random bracket to get the pulley off.
Now I could get the bottom timing belt cover off.
Pulled the timing belt off, and started taking out the bolts for the water pump. At this point if I plugged the hole it was leaking from, it would flow out from a vent hole on the water pump sprocket, meaning that the impeller shaft seal is the culprit here, and I'm going to be needing a new water pump. Idler pulley #2 is in the way of the water pump of course, that that's off too.
So, I ordered a new water pump, new gaskets, and a new timing belt. Does anyone know offhand if I can use the alternater belt listed for no a/c with the factory tensioner, or will I have to swap on a ribbed pulley?
I guess I'm going to be taking a bunch of that castrol putple stuff to this engine now that everything's off of it while I wait for the parts to show up, make it look all silver again...
