Ok, so I removed my TPS and replaced it with a 4AG TPS (friend of mine said they were the same...) that didn'tfix anything, it just made a very bouncy idle, and when I hit the throttle it does nothing. I then replaced it with the original TPS (which wasn't TOO messed up) and it just did the same thing as the 4AGone (bouncy idle, no throttle)
I tested the plug for the TPS, there was resistance (not sure the right amount, because I dont have the link to the BGB..) in the second wire down of the 4.
Trying to locate the ECU on this car, not sure where it is tho.. I think it might need resetting via unplugging and re-plugging it in.
Any ideas guys? Whats the link to the BGB on this site?
