F.S. 1990 Pearl Blue ST185
Celica All Tracs for sale
Postby Brad.Miller » Thu Aug 24, 2017 12:49 pm
Item: 1990 Pearl Blue ST185 With Original Window Sticker
Item Condition: Practically new Drivetrain , just needs paint
Price: $8500 OBO
Extra Info: Primer Gray RC Bumper
This is a 100% rust free car you can eat off the underside!!!!! You would have a difficult time finding a more solid 185.
I have my eyes set on a different project so I have to part with this one.
MOTOR (New Stock Parts)
• Toyota Shortblock
• Water Pump
• Oil Pump
• Idlers
• Timing Belt
• Rebuilt Head w/ New Exhaust Valves (INTAKE VALVES ORIGINAL)
• Water Neck w/ Sensors (also HPC coated)
• Engine Wiring Harness
ENGINE COMPARTMENT (New)
• A/C Compressor (converted to R134)
• A/C Lines
• PS Pump
• PS Lines / Hoses
• Radiator
• Fuel Filter
• Heater Hoses
• Hoses From Hell
• Radiator Hoses
• Alternator
• New Motor Mount
• New Steering Rack
TRANSMISSION
• Every Synchro
• Every Bearing
• Shift Forks
• New Oil Pump Magnet
• Shifter Cables
SUSPENSION / OTHER
• Rebuilt Front Axels
• New Superpro bushings in all links/hubs/swaybars
• New front hubs / knuckles / ABS sensors / wheel bearings
• Rear wheel bearings have been replaced
• ST205 Torsen LSD
BODY
• New Fuel Lines (tank to front)
• New Fuel Tank
• New Fuel Tank Protector
• New Heater Core
• Battery Relocated to Rear (original setup for optima now have full size regular Die Hard)
• Rebuilt Driveshaft (carrier bearings and spyders)
• New Rear Diff Cushion
• New Bushings in Rear Subframe
• New Transmission Oil Cooler Lines
• Clear Turn Signal / Market Light Lenses
HPC COATED PARTS
• Front Suspension (a-arms)
• Front Crossmembers
• Front and Rear Sections of Driveshaft
• All Heat Shields
• Rear Subframe
• Real Suspension (trailing arms, etc.)
• Oil Pan
• Valve Cover
• Intake Manifold
• Water Bypass Pipe
• Every Mount on the Transmission
• Transmission Oil Cooler Pipes
• Turbo Heat Shield
• Every Bold in Engine Compartment
• Etc, etc. etc.
NEW AFTERMARKET / PERFORMANCE PARTS
• Fabricated TMIC w/ External Blow off Valve
• Aeromotive FPR
• Earls Braided Fuel Lines
• Wolfkatz Fuel Rail
• Toyota Supra 550cc Injectors (purple top)
• AEM Tru Time Cam Gears
• HKS Valve Springs
• HKS 264 Cams
• TTE Metal Head Gasket (1.2)
• ARP Head Studs
• Aussie Mild Steel DP (HPC Coated)
• Aussie SS Midpipe (no cat)
• HKS HiPower Catback (one w/ 4” trash can outlet) – also have silencer uninstalled
• ST205 Torsen Limited Slip Rear Differential
• ATS CT27 (on a CT26 from 56
• ATS ROM Tune (for above mods including injectors)
• Whiteline Rear Swaybar
• 17" Gramlite Wheels with Nitto NT05 Tires, Sticky and plenty of life left in them
• AEM Gagues – Truboost, A/F Ratio, Oil Pressure
• Superpro Bushings in Front and Rear Links/Hubs/etc,
• Tein Coilovers
• Rocketeer? Willwood Big Brake Kit (front and Rear) – 2 piece Rotors
• Whiteline Rear Strut Brace
Preferred Contact Method: Email me @ BradMiller@runbox.com
Pictures:
Brad.Miller
Re: F.S. 1990 Pearl Blue ST185
Postby BoostedBlueToyotas » Thu Aug 24, 2017 1:12 pm
This is my old car. About as close to a new alltrac as you could find :). I replace everything on this car. Good luck with sale
Tim Plessing
Columbia, MD
BoostedBlueToyotas
Postby Anoo21 » Thu Aug 24, 2017 7:35 pm
This would an awesome addition to my blue st165, I am buying a house right now so can not do it. Wrong timing, good luck with the sale and maybe when it comes up for sale again I will be in the market. Very clean looking 185 bud.
Anoo21
Postby Brad.Miller » Thu Aug 24, 2017 7:38 pm
Sale Pending .........
Brad.Miller
Postby Brad.Miller » Tue Aug 29, 2017 5:49 pm
Sold Sold Sold................
Brad.Miller
Return to All Tracs For Sale
