1992 Super Red All Trac running project car
Celica All Tracs for sale
Postby Nitro_Alltrac » Mon Aug 28, 2017 9:15 am
PRICE REDUCED!! $2350 OR BEST OFFER
SOLD!
Up for sale is my 1992 All Trac. I bought the car from a guy in New Hampshire in 2006 and I've had it ever since. It's been a great car and I love it but I've reached the point of where it's time to move on.
The car has been little problem in the time that I've had it. Simple maintenance mainly. It does have some rust issues though and I've done my best to try and fix them but I don't have the best welding skills.
I have most of the panels that are needed to finish the body repair. They came from two rust free GT-S Celicas.
I'm offering this a project car. It is a good car and I feel that it is savable and has life left in it.
Here's the bad:
There is rust. I don't think it is terminal with someone with good fab/welding skills. I've got pictures of the bad points below. The left inner rocker is the worst place. The lip on the right rear quarter
had a couple of bad spots that I've cut out. I have the wheel opening to fix it. I've replaced the lower front and rear of the left quarter. The rear panel replacement needs to be finished. I fixed a couple
of places underneath on the left floor pan but they weren't that bad.
There is a head gasket leak to the outside of the block on the front of the engine. I believe this happened with the engine overheated a couple of years ago due to a stuck thermostat. I've run exhaust gas checks
and there is no water getting into the oil so it looks like the leak to the outside is the only spot in the gasket. It's not a bad leak but it does require adding cooling every week and a half or so if driving it
regularly.
There's a stutter in the ignition under acceleration. You accelerate, hit the stutter and then drive through it. It doesn't do it while cruising. It just started doing this recently.
The passenger door latch sticks sometimes and won't let the door open. I just haven't torn the door apart to fix it or replace the latch.
These are main bad items. Keep in mind this is a 25 year old car.
Here’s the list of what’s on the car that I can think of. I'm sure I've missed something.
OEM CS bumper cover and crash bar and factory grille pieces.
Mishimoto Aluminum radiator
ST205 WTA intercooler with Ford Cobra Heat Exchanger and Bosch water pump
Full third gen electronics conversion using a Berk conversion harness and a 205 ECU. I have the CEL light issues fixed for the WTA level sensor. No CELs what so ever from the conversion (For those that don’t know, one big piece of this is that it removed the air flow meter).
ST205 550cc injectors with a Mad Katz fuel rail
Twos R Us solid brass shifter bushings
Koni Yellow inserts in front, Koni RACE inserts in converted strut housings in the rear. Not that many miles on them.
B&G lowering springs
Whiteline adjustable rear sway bar
Mario Koenig solid rear diff mount
ST205 Torsen rear diff
4 pretty much new Hankook Ventus V2 Concept 2 H457 tires. I’ll have to check my log but the fronts probably don’t even have 500 miles. The backs maybe 1-2000.
4 Konig Incident 15x6.5. I painted them a metallic grey as I was never crazy about the polished finish. These are dual bolt pattern, 5x100 and 5x114.3. There in good shape.
TWM short shifter
Have the correct All Trac luggage area cover
Rear strut bar
JDM clear front side markers
Cibie H4 headlight conversion. The shells came out of a Eurospec Mercedes
Goodridge stainless steel brake lines
Blitz Nur Spec Stainless exhaust
Blitz blowoff valve
Seats are in pretty good condition. I replaced the driver’s seat with one out of a GTS several years ago. The passenger seat is good condition. Rear seats are good but dry.
Carpet has seen better days.
Dash is in pretty good shape. Some small holes where someone had mount a phone bracket back in the day.
Pillar gauge pod with Autometer Phantom Boost, and oil pressure gauges.
WRX leather shift knob
AC is still installed but needs leaks fixed.
Cruise control works intermitantly.
I’m sure I’m missing some other things.
I painted the car with Sherman Williams Automotive Super Red Base/Clear about 7 years ago. With the exception of the repair areas the paint is holding up well. This was my first paint job so there are some runs in the clear.
The chassis has 287K+ miles on it. The engine is a JDM replacement with around 150K miles. I’m assuming that the transmission and transfer case are JDM as well but I don’t really know. They work fine and shift good. Timing belt and water pump were changed while I was in Texas. I’ll have to check the exact mileage but it’s probably less than 15K. Toyota belt and Aisin water pump.
I'm asking $2350. The car is located in Nitro, WV.
[url="http://www.celicatech.com/gallery/showimage.php?i=24587"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24585"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24586"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24588"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24582"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24581"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24584"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24592"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24590"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24591"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24595"]Image[/url]
Left Floor pan 1
[url="http://www.celicatech.com/gallery/showimage.php?i=24594"]Image[/url]
Left Floor pan 2
[url="http://www.celicatech.com/gallery/showimage.php?i=24593"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24610"]Image[/url]
Underbody surface rust
[url="http://www.celicatech.com/gallery/showimage.php?i=24609"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24608"]Image[/url]
Left rocker rust
[url="http://www.celicatech.com/gallery/showimage.php?i=24607"]Image[/url]
Right rocker repair
[url="http://www.celicatech.com/gallery/showimage.php?i=24606"]Image[/url]
Right rocker
[url="http://www.celicatech.com/gallery/showimage.php?i=24605"]Image[/url]
Right rear rocker
[url="http://www.celicatech.com/gallery/showimage.php?i=24603"]Image[/url]
Left underside
[url="http://www.celicatech.com/gallery/showimage.php?i=24602"]Image[/url]
Left inner rocker. This is the WORST spot
[url="http://www.celicatech.com/gallery/showimage.php?i=24601"]Image[/url]
Left underside
[url="http://www.celicatech.com/gallery/showimage.php?i=24599"]Image[/url]
Left rear quarter repair
[url="http://www.celicatech.com/gallery/showimage.php?i=24598"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24597"]Image[/url]
Left inner rocker
[url="http://www.celicatech.com/gallery/showimage.php?i=24580"]Image[/url]
RR wheel opening
[url="http://www.celicatech.com/gallery/showimage.php?i=24579"]Image[/url]
RR wheel opening
[url="http://www.celicatech.com/gallery/showimage.php?i=24578"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24577"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24576"]Image[/url]
Driver's seat
[url="http://www.celicatech.com/gallery/showimage.php?i=24575"]Image[/url]
[url="http://www.celicatech.com/gallery/showimage.php?i=24574"]Image[/url]
Last edited by Nitro_Alltrac on Mon Oct 30, 2017 11:24 pm, edited 3 times in total.
Mike
92 All Trac - Daily Driver
Nitro_Alltrac
Re: 1992 Super Red All Trac running project car
Postby slowgt92 » Fri Sep 01, 2017 5:51 pm
Is the car registered, and what's the title situation? You mentioned having replacement panels from a gt-s. Do these include the rocker panels? I'm interested in the car, though I need to finish mine, which I almost am. I really love these cars and I see this as an option to restore the car to its former glory and save another alltrac... These cars are way to good to be scrapped. Thanks!
slowgt92
Postby Nitro_Alltrac » Fri Sep 01, 2017 8:04 pm
Yes, the car is registered. I've been driving it off and on. One reason that I'm selling is that I have new 86 on the way and I need the room.
The rocker pieces I mentioned are from a GT-S but not the full rocker. I cut the outer skin off of the car. It's the length and width of what you see on the outside of the car with door shut. The rust in the out rockers is confined to that part of the side. The door jambs are good.
I can get a picture of the rocker pieces if that would help. I have taken a piece out the right rocker to fix the one hole but I have the rest. The left piece I complete.
Mike
Nitro_Alltrac
Postby slowgt92 » Fri Sep 01, 2017 8:42 pm
Nitro_Alltrac wrote:Yes, the car is registered. I've been driving it off and on. One reason that I'm selling is that I have new 86 on the way and I need the room.
Ok thats great thanks. the main thing that has me worried is the left inner rocker. rust is almost always worse than it looks, but I have seen a few people that had ones repaired where there literally was no rocker left, but I know Toyota used to make re manufactured pieces. I might be able to find some somewhere. The big thing i just wanted to let you know is that I am interested, but I have a few things to finish up on my gt first so if its still for sale in a few weeks I definitely would want to come take a look. Thanks!
slowgt92
Postby Nitro_Alltrac » Fri Sep 01, 2017 10:06 pm
No problem. Thanks for checking in.
Mike
Nitro_Alltrac
Postby Nitro_Alltrac » Sat Sep 02, 2017 4:11 pm
Updated the original post to reflect that I had replaced the radiator about a year or so ago with a Mishimoto aluminum unit.
Mike
Nitro_Alltrac
Postby 8BitBrody » Sun Sep 03, 2017 10:02 pm
slowgt92 wrote: the main thing that has me worried is the left inner rocker. rust is almost always worse than it looks, but I have seen a few people that had ones repaired where there literally was no rocker left, but I know Toyota used to make re manufactured pieces. I might be able to find some somewhere. Thanks!
Check out http://alfaparts.net/
I haven't ordered parts from them myself, but I've heard good things. I've been in talks with one of the guys there to get panels for my 185, and his quote seemed reasonable. They have the floor pans, rockers, and quarters. Just shoot them an email, as I don't think the parts are listed on their site, for some reason. If you do get them, be sure to let me know what you think of quality and such!
8BitBrody
Postby Nitro_Alltrac » Mon Sep 04, 2017 1:14 am
I've heard that they are making some 185 stuff and that the quality is good.
Mike
Nitro_Alltrac
Postby lalojamesliz1 » Mon Sep 04, 2017 4:43 am
Sorry to see it's for sale buddy but I understand enough is enough
Great guy here ladies and gents :)
91 Celica all-trac gen3 swap
87 toy 5speed long bed
69 mustang
08 sequoia
14 avalon
and a 2 car garage :shoots:
lalojamesliz1
Postby Nitro_Alltrac » Mon Sep 04, 2017 1:16 pm
^Thank you sir!
Mike
Nitro_Alltrac
Postby lalojamesliz1 » Mon Sep 04, 2017 3:26 pm
Nitro_Alltrac wrote:^Thank you sir!
I forgot to mention it's ed from celicatech :D
It's nice to see that ecu and patch harness is still working.
Good luck on the sale
69 mustang
08 sequoia
14 avalon
lalojamesliz1
Postby Nitro_Alltrac » Tue Sep 12, 2017 1:19 am
Price reduction.
Mike
Nitro_Alltrac
Postby Rabman369 » Sun Sep 24, 2017 7:09 am
Would you ever consider a trade?
Rabman369
Postby Nitro_Alltrac » Sun Sep 24, 2017 1:28 pm
Sorry, no.
I've got a potential sale in process right now. If it falls through, I'll let everyone know.
Mike
Nitro_Alltrac
Postby gt4ferko » Sun Oct 15, 2017 6:54 pm
Mine!
gt4ferko
Return to All Tracs For Sale
