SOLD - 1992 Alltrac for sale in Maryland
Celica All Tracs for sale
Postby dragstang86 » Wed Nov 29, 2017 1:28 am
1992 Alltrac - black but originally white
Loaded, leather, system 10 etc.
There is a ton of money in the car in parts alone. Nearly rust free with the only spot starting being a small spot on the bottom of the drivers rear quarter panel lip. In the elevation of New Mexico the car made 337awhp/279awtq. Will make more power closer to sea level with tuning and engine is built to handle well more. Re-tuning for sea level was started but never finished after the car left NM. Car runs fine but I'm sure the tune isn't perfect. Engine only has about 2200 miles on it. 99% of those miles were a cross country trip from New Mexico.
Car is in good shape overall and most everything in the drivetrain is almost new. Paint isn't perfect but shows well with the biggest issue being the paint chipping on the front bumper. Interior is in good shape with the exception of the stereo was stolen out of it and the plastic piece surround it cracked as seen in pictures. All the wiring is still there however. The small tweeter speaker on the drivers door is also missing. Only other issues are the battery is old and won't keep a charge and either the speedometer gear or speedometer cable broke (can't remember which) when the engine went in so the chassis actually has about 2200 more miles on it than the odometer reads.
Chassis miles - 112,226 show but actual is about 114,500
Engine, clutch miles - ~2200
I have the dyno sheet and folders full of documentation on the car.
Engine- (Built by 3S-GTE Specialist, Chris Katthage of Engine Logics, in the Houston, Texas area)
JE 9.0:1 Pistons .020 over
Carillo Rods
Clevite Bearings
ARP Rod and Main bolts and head studs
HKS 272 Intake Cam
HKS 264 Exhaust Cam
Fidanza Adjustable Cam Gears
Crower Valve Springs
Crower Retainers
Shimless Bucket Conversion
Ferrea Stainless Steel 1mm oversized valves
Port and Polished head
KO Racing EGR eliminator
KO Racing Phenolic TVIS Eliminator
Turbo-
KO Racing Street Brawler 50 trim T3/T4 .63 A/R TO4E-50 kit
Tial Sport 38mm external wastegate
ATS Throttle Body Inlet
Bay Area front mount inner cooler
Drivetrain
ACT Chromemoly Prolite Flywheel
ACT 5 puck un-sprung clutch
Ignition, Fuel and Engine Management
AEM Engine Management System
Supra 550cc Injectors
ATS fuel pressure regulator
Walboro fuel pump
MSD Blaster Coil
HKS electronic boost controller
HKS boost gauge
AEM Wide band gauage
Suspension and Braking
Koni Adjustable Struts
TRD lowering springs
Cusco Front Strut Bar
Wilwood 6 piston front brake kit
Stillen Rear Brake Rotors
Rota Sub Zero 18 inch wheels
RC front bumper
$7500
Will consider trade offers but they have to make financial sense
Pictures here: https://baltimore.craigslist.org/cto/d/ ... 02251.html
92 All trac
dragstang86
Re: 1992 Alltrac for sale in Maryland
Postby SLC Punk » Tue Dec 05, 2017 3:36 pm
Very nice car! Let me know if there are any parts you want to sell separately.
GLWS!
-Travis
1992 ST185- sold
2014 4Runner Trail
2018 Audi S5 Sportback
1978 F250-for sale
SLC Punk
Postby dragstang86 » Sun Dec 10, 2017 5:56 pm
Sale Pending
92 All trac
dragstang86
Re: SOLD - 1992 Alltrac for sale in Maryland
Postby EricGT4 » Wed Feb 28, 2018 6:12 pm
Who did this car go to? I used to own it.
Also, did you replace the block? When I sold this to him there was a hairline crack in one of the cylinders that would pressurize the water jacket at boost.
If the new buyer has any questions about this car, feel free to contact me. Everything that was put into it was put there by me and I am the one who drove it from NM to the North East.
1992 Alltrac - 350whp - SOLD
EricGT4
Return to All Tracs For Sale
