Parting Out ST185
All Trac Parts
Re: Parting Out ST185
Postby 3SDNA » Fri Nov 11, 2016 1:12 am
Hello, would you part with the clutch hard line that runs from the slave cylinder to the soft line on top of the tranny?
Thanks.
3SDNA
Postby cozmic512 » Tue Nov 22, 2016 7:38 pm
PM Sent..
Give me a call I am right on LI.
thanks
631-413-5231
regards,
Cory
92 ST185
cozmic512
Postby FC Zach » Tue Nov 22, 2016 7:41 pm
shogun86 wrote:The press-in inserts are still available. I don' t mid shipping the larger pieces. The car doesn't have a hatch carpet. I'll check the condition of the panels, but I won't be next to the car by Thursday.
What's the status on this stuff?
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby shogun86 » Sat Nov 26, 2016 5:22 pm
The trunk panels are in good condition and they are still available. Someone was suppose to pick them up locally, but I haven't heard from them.
shogun86
Postby FC Zach » Sat Nov 26, 2016 7:58 pm
Alright, I'd like the left and center hatch plastics as well as the door panel inserts. Shipping to Eagleville, TN 37060
FC Zach
Images: 9
Postby blk_panther » Mon Nov 28, 2016 6:45 am
PM Sent... on the Rear subframe, when you get to removing it.
-'88 ST165 - Awaiting upgrades
-'95 Honda XR600
blk_panther
Postby 90ToyAllTrac » Mon Nov 28, 2016 9:11 pm
I need all the mounting hardware, clips, rubber flaps for the front mud guards.
And all of the seat rails, tracks, brackets.
90ToyAllTrac
Postby All-TracDreams » Tue Nov 29, 2016 10:54 pm
I need the complete front driver-side ABS wheel speed sensor assembly, assuming it's not rusted out or otherwise broken. Also need the PASSENGER-side black plastic trim piece circled in yellow below:
All-TracDreams
Postby shogun86 » Wed Nov 30, 2016 4:11 pm
I doubt that the sensor is any good, but i'll check. I'll also check for the plastic trim.
All-tracDreams wrote:I need the complete front driver-side ABS wheel speed sensor assembly, assuming it's not rusted out or otherwise broken. Also need the PASSENGER-side black plastic trim piece circled in yellow below:
90ToyAllTrac wrote:I need all the mounting hardware, clips, rubber flaps for the front mud guards.
I should have everything you need. PM me a offer.
3SDNA wrote:Hello, would you part with the clutch hard line that runs from the slave cylinder to the soft line on top of the tranny?
Thanks.
Do you still need the line?
FC Zach wrote:Alright, I'd like the left and center hatch plastics as well as the door panel inserts. Shipping to Eagleville, TN 37060
I don't have the driver side door panel insert. It was removed before I purchased the car.
shogun86
Postby cozmic512 » Thu Dec 01, 2016 11:32 pm
Hey man,
Id like the shifter surround with or without the boot and the center piece on the center console that holds the ashtray and radio etc. Also looking for the trunk center rear panel, and would like to look at the gas tank and tank trim. I am about 15 mins from you so I can come anytime.
PM or text me.
Thanks
631-413-5231
regards,
Cory
92 ST185
cozmic512
Postby fhalperformance » Fri Dec 02, 2016 2:24 am
What do you want for the whole car?
'93 trac - V6TT project.
'91 trac - 564awhp.
'91 mr2 - parting out.
'04 ducati 999
'04 tacoma TRD - for sale
fhalperformance
Postby FC Zach » Fri Dec 02, 2016 5:37 am
Well, I'll take what you have as well as the plastics but I understand if you sell locally. .
cozmic512 wrote:. . looking for the trunk center rear panel. I am about 15 mins from you so I can come anytime.
PM or text me.
Thanks
631-413-5231
FC Zach
Images: 9
Postby shogun86 » Fri Dec 02, 2016 1:49 pm
fhalperformance wrote:What do you want for the whole car?
I open too reasonable offers, but there is a few things that i'm going to keep for my car.
cozmic512 wrote:Hey man,
PM or text me.
Thanks
631-413-5231
I'll be at the shop today. I have the shifter surround without the shift boot, and the center console has a red carbon fiber overlay. The trunk center panels are sold, and i'll have to check the condition of the gas tank.
shogun86
Postby Mike Lawson » Fri Dec 02, 2016 4:23 pm
Do you have the plastic pieces that go around the steering column? I need one that has openings for the turn signal & wipers/etc accessories on the left and right, as well as the tilt wheel handle on the left. I have a st184 (GTS) with a gen 4 3sgte, don't have the front-to-rear crossmember mounted because I don't have the rubber bushings that go above/below the 4 bolt holes, mine are all dry-rotted and some completely missing. Idk if the st185 crossmember uses the same or similar hardware but if you have that I'd be interested in seeing pics and buying if it will work. Also need 2 floor pan plugs (I'd take all 4 honestly if they're in good condition.. can't hurt to have more) and also the rubber lower supports for the radiator if they're in good shape. Shipping to 33613 (Tampa FL)
Mike Lawson
Postby cozmic512 » Fri Dec 02, 2016 9:36 pm
Tried to PM. I am around. shoot me a text and Ill come by. I can see what you have left and what I might want. I dont want the hatch plastics, but the lower pieces.
Anyway, let me know when you are around and where the shop is and Ill come by.
Thanks
Cory
631-413-5231
regards,
Cory
92 ST185
cozmic512
Return to Parts For Sale
