Switch to full style
All Trac Parts
Forum rules
Post a reply
Part cleanout gen2-3 updated and parts added
Tue Dec 13, 2016 10:41 pm
Hey guys im trying to clean out some of my old supply. and trying to make some money to fund the new engine build. some stuff was for future plans that have changed and other were spare parts that were removed everything worked when they were put into storage. but are being sold as is!
1.sold
2.sold
3. sold
4. Sold
5. KO racing T3 turbo adapter with 3in v band down pipe and rerouted dump tube ceramic coated $400.0
6. x2 catalytic converters both in good condition (1 might be for the gen3) but the bolt holes look similar. $100 per ( again heavy so shipping will be pricey)
7. sold
8. 92-93 usdm 3sgte engine harness (i think the rad temp sensor plug was damaged ) still easy fix. $250
9. sold
10. Sold
11. st185rc hood vents $135 for the rc vents (white pictured but I have red and black. I can only sell one set tho I need the other for my hoods...
12. x2 alternators 1 with duct and plug $65.0 / SOLD / and the last im not really sure where it came from ...$20
13. st185 Cruise control module worked great when removed. $125 ( hell im kinda not sure if i should sell this ...lol)
14. 90-93 rc hood x2. 1 needs some work done to it but has all the bolt on's $550 and the other is a red cs hood and is damn near mint condition might have a few small scratches but is beautiful $1000
All prices are obo and not including shipping.
Also i have a few extra coolant hoses/ brackets/body panels/ and turbo lines that are not pictured if your needing some random parts please let me know and i will see what i can dig up.
Ray.
https://goo.gl/photos/Stuyp3GFMuQ8yDTm9
Re: Part clean out gen2-3 and some aftermarket!!!
Wed Dec 14, 2016 12:01 am
"8. st185 alt snorkel $65"
I'm missing everything for cooling the alternator, is this all I need? Pics?
Wed Dec 14, 2016 2:15 am
Pm'ed
Wed Dec 28, 2016 6:47 am
Are the stock 3gen cams much different from the 2nd gen?
Wed Dec 28, 2016 12:22 pm
If I'm correct they have 6 degrees more timing built into them and a few more points of lift
Wed Dec 28, 2016 6:20 pm
rrain3288 wrote:If I'm correct they have 6 degrees more timing built into them and a few more points of lift
trying to find out if its worth it with a stock 2nd gen rebuild im doing, im going with ATS adjustable cam gears as well. I'll get back to you asap. still working on getting my engine/trans out this week.
Re: Part cleanout gen2-3 updated and parts added
Sun Jan 22, 2017 5:29 pm
Bump parts added
Thu Apr 27, 2017 5:56 pm
Hey, can I see a pic of the trans cooler with lines?
Sat May 13, 2017 9:43 am
I'm looking for the Gen2 intake manifold stays/supports. Aka the two metal bars on the back of the intake manifold that connect to the block. Hope there's a couple somewhere in your pile of goodies! Thanks
Sun May 21, 2017 11:35 am
You have any pics of the rc hood that needs work?
Tue May 23, 2017 11:52 am
PM sent!
Post a reply
