St165 part out
All Trac Parts
St165 part out
Postby outinnowhere3193 » Mon Apr 17, 2017 3:10 am
I'm using the drivetrain and what not in a gen 7 build. Basically the car is a rolling chassis There's tons of good parts I can post pictures as needed. Ask me about a part and I'll post a reply with item details.
Right now my build is my thoughts but i figured I'd go ahead and post so if there's something you need it's available.
Send me the requested part or parts and a number to text and I will send pics
Thanks Jeremy
PICTURES CLICK HERE: https://drive.google.com/folderview?id= ... jByWVZqVWs
Last edited by outinnowhere3193 on Wed Apr 19, 2017 1:59 am, edited 2 times in total.
outinnowhere3193
Images: 5
Re: St165 part out
Postby zaluss » Mon Apr 17, 2017 3:31 am
Interested in the gas tank and the driver side mirror...PM'd.
zaluss
Re: St165 part out
Postby MST Engineer » Mon Apr 17, 2017 12:30 pm
I'm looking for driver and passenger window switches and sunroof metal panel. Let me know if you have those.
MST Engineer
Re: St165 part out
Postby outinnowhere3193 » Mon Apr 17, 2017 2:14 pm
Replies sent
outinnowhere3193
Images: 5
Re: St165 part out
Postby SkagTits165 » Mon Apr 17, 2017 2:21 pm
Do you have these inserts?
SkagTits165
Re: St165 part out
Postby outinnowhere3193 » Mon Apr 17, 2017 7:09 pm
SkagTits165 wrote:Image
Pm sent but yes I do.
outinnowhere3193
Images: 5
Re: St165 part out
Postby Redrkt01 » Tue Apr 18, 2017 7:26 pm
You should post a bunch of pics of the car. Inside and out. Now they're needed....
1989 ST162
1988 ST165 Black
1988 ST165 Red Parts Car
Redrkt01
Re: St165 part out
Postby 4thgenceli » Thu Apr 20, 2017 3:46 am
Plastic pieces surrounding the steering column/ignition
ignition switch with key
all door lock assemblies (presuming matching key to the ignition)
Don't see it in the pictures -- but are there any fuseboxes in the engine bay still? Looking for a couple of those as well.
4thgenceli
Re: St165 part out
Postby outinnowhere3193 » Fri Apr 21, 2017 4:09 am
4thgenceli wrote:Plastic pieces surrounding the steering column/ignition
Fuse boxes no.
Ignition and key locks match. I'll send ya a pm
outinnowhere3193
Images: 5
Re: St165 part out
Postby 4thgenceli » Fri Apr 21, 2017 4:38 am
Fuse boxes no.
Cool beans.
Sent from Naboo
4thgenceli
Re: St165 part out
Postby mkernz22 » Fri Apr 21, 2017 2:12 pm
How much for the drivers side seat belt buckle? The part that is mounted to the seat, not the actual belt.
Also, how is the drivers side quarter panel?
mkernz22
1995 Toyota Celica
Re: St165 part out
Postby pigfragger » Fri May 05, 2017 10:57 pm
I need the shift knob. Please PM. Thank you.
pigfragger
Re: St165 part out
Postby outinnowhere3193 » Sat May 06, 2017 2:42 am
pigfragger wrote:I need the shift knob. Please PM. Thank you.
I don't think mine is the oem shift knob.
outinnowhere3193
Images: 5
Re: St165 part out
Postby pigfragger » Sun May 07, 2017 11:59 pm
Darn. Thanks for the clarification.
pigfragger
Re: St165 part out
Postby 88gt4DE » Tue May 16, 2017 9:51 pm
I'd like the entire left pop up head light brackets and all. Doesn't matter if the motor is good or not. LMK ...
Return to Parts For Sale
