Brand New Motor Build Parts! Mahl, Eagle, ACL, ARP, GEN3 EFI
All Trac Parts
Postby Scrap Metal » Sun Aug 20, 2017 9:32 pm
Hey guys, I blew up my gen2 sooner than I was hoping and I do not have time to properly build a motor at this point in my life so I am going with the easier/quicker gen4 motor swap for now. All parts are brand new open box, unless otherwise stated.
BRAND NEW
1. MAHLE Pistons TOY378405I04 86.50mm (~$600) Price Reduced $320shipped
2. EAGLE Rods 5.428 CRS5428T3D (~$375) $275 Shipped SOLD
3. ACL Race Main, Rod & Thrust Bearing Kit 5M8361H 4B8366H 2T1689 (~$130)$100 Shipped SOLD
4. ARP Main Stud Kit 203-5404 (~$120) $90 Shipped
5. ARP 3S-GTE Head Stud Kit 203-4204 (~$150) $100 Shipped SOLD
USED PARTS
1. gen2 3sgte Engine Block $100
2. gen2 3sgte Cylinder Head Stock cams $200
3. COMPLETE GEN3 EFI SETUP RUNNING ON GEN 2 3sgte $550 SOLD
Converted Gen 2 Harness, ECU, 540cc, AIT Sensor, MAP Sensor, COIL, etc... pretty much everything you would need, this was running on my gen2 3sgte until I ran it out of oil. I'm going gen4 swap so I don't need this.
Parts Located in SoCal 91761 Paypal, cash, venmo...
More pics coming, in process.....
Scrap Metal
Re: Brand New Motor Build Parts! Mahl, Eagle, ACL, ARP, GEN3
Postby Tecker185 » Sun Aug 20, 2017 11:02 pm
What did the gen3 efi setup come off of?
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby Scrap Metal » Sun Aug 20, 2017 11:37 pm
its currently on my alltrac. it was running great until i tan the motor out of oil lol... it was an old gen2 anyway... instead of building a gen 2 block like i had planned I'm just going with an st215 motor so i don't need any of these parts
Scrap Metal
Postby Tecker185 » Sun Aug 20, 2017 11:49 pm
What year alltrac
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby Scrap Metal » Mon Aug 21, 2017 12:15 am
woops... forgot to list that
st185 1990
Scrap Metal
Postby Tecker185 » Mon Aug 21, 2017 6:44 pm
Haha so will that include everything to get my 90 running on gen3 efi?
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby Scrap Metal » Mon Aug 21, 2017 7:56 pm
Yeah, this was running perfect on my gen2 st185. Only check engine light I got was the speed signal due to my failing speedometer. It will come with everything including the MAT sensor in the throttle body (didn't list that in the ad). I believe its either ATS or Berktechnology that makes the adapter I'm using.
Basically I would be giving you the injectors and rail, and all the sensors needed. The engine harness and ECU.
The wiring was actually done by the previous owner, his board name is tubasteve if you want to see his build thread on the red st185, it is the one I own now.
At the ECU he spliced the wires himself with connectors, I never had any issues, check engine light worked like it was supposed to, some people prefer buying a patch harness to go in between, but this one doesn't have that.
Actually, I just remembered, the only thing you will need is the Intake temp sensor that goes near the filter. The one currently on it is a smaller version that doesn't fit snugly in the stock size piping... these IAT sensors are readily available though so it shouldn't be a big deal, as you should already have one currently.
Everything is still on the car. Recently I did repair the distributor plug wire that got caked in oil and one of the pins slid out, so as far as the harness goes I would make sure that its still snug when you plug in the dizzy.
Scrap Metal
Postby Tecker185 » Mon Aug 21, 2017 8:30 pm
I sent you a pm
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby Scrap Metal » Tue Aug 29, 2017 6:23 am
GEN3 EFI, EAGLE RODS, ACL BEARINGS, ARP HEADSTUDS ARE ALL SOLD
MAHL Pistons and ARP Main Stud Kit still available. Make me an offer!!!
Scrap Metal
Postby awdmofo » Wed Aug 30, 2017 4:27 pm
PM sent, I think I'll take the ARP kit you have :D .
2013 Camaro LS 6-sp (daily)
2005 Yamaha R6 (sold)
2001 Spider (sold)
1990 alltrac (sold)
1991 MR2 turbo x2 (Sold)
awdmofo
Postby Scrap Metal » Tue Sep 05, 2017 2:14 am
Price Reduced!
MAHL PISTONS $450 SHIPPED!
Scrap Metal
Postby Scrap Metal » Thu Dec 14, 2017 7:17 pm
Fire Sale
$320 SHIPPED BRAND NEW MAHL PISTONS
Scrap Metal
Return to Parts For Sale
