St165 engine part out
All Trac Parts
Postby dbucks2k » Wed Jan 17, 2018 8:48 pm
Parting out the engine from my st165. It has around 130k miles on it. Everything still works great, just pulled the engine when I did a fourth gen swap. I can ship pretty much any part of it besides the block itself. Let me know what you need. I'll add pictures when I get home. I'm located in Montana
dbucks2k
Re: St165 engine part out
Postby Anoo21 » Thu Jan 18, 2018 10:49 pm
Do you still have the dip stick in good condition?
Anoo21
Postby entrax » Sat Jan 20, 2018 3:43 pm
alternator sub harness?
it's the wiring that goes into the snorkel of the alternator and other side clips onto the front of the alternator. as well as the green plug on the engine-side harness pigtail.
thanks
1991 MR2 Turbo [May 2013-
1988 Celica turbo4WD [Mar 2015-
1987 GT-S [November 2011-April 2013]
1988 GT [October 2010-October 2011]
1989 GT [October 2011]
1987 Tercel Wagon 4wd [August 2014-May 2015]
entrax
Postby dbucks2k » Sat Jan 20, 2018 7:27 pm
I have a dipstick. But I don't think it's the original one so I don't how accurate it is.
And I'm using the alternator wiring on my new engine. I pretty much hacked up all the wiring but I still have most of the plugs minus the alternator and the fuel pump relay.
dbucks2k
Postby dbucks2k » Sat Jan 20, 2018 7:28 pm
Actually I should still have the plug that goes into the alternator. But I'm using the other plug to the harness.
dbucks2k
Postby Redrkt01 » Tue Jan 23, 2018 4:28 pm
Engine fusebox?
1989 ST162
1988 ST165 Black
1988 ST165 Red Parts Car
Redrkt01
Postby ST165myGUY » Tue Jan 23, 2018 5:26 pm
Do you have the Intercooler/ Charge cooler level sensor?
ST165myGUY
Postby dbucks2k » Tue Jan 23, 2018 6:15 pm
I'm still using the fusebox.
And I've already sold the intercooler.
dbucks2k
Postby dbucks2k » Tue Jan 23, 2018 7:33 pm
dbucks2k
Postby entrax » Tue Jan 23, 2018 10:12 pm
dbucks2k wrote:Actually I should still have the plug that goes into the alternator. But I'm using the other plug to the harness.
damn the one that goes into the harness is really the one i need
how about intake hose from filter to turbo?
entrax
Postby dbucks2k » Tue Jan 23, 2018 11:21 pm
I do have that. The edge on the turbo side has some cracks on it but it still sealed good. But it has like an inch wide hole from where my bov was setup to recirculate.
dbucks2k
Postby entrax » Wed Jan 24, 2018 6:03 pm
so close! that little bit of splitting is perfect, but i'm going for an all-oem set up.
thanks anyway
entrax
Postby dbdbdb » Thu Mar 01, 2018 6:10 pm
Hi, are selling the stock st165 ecu? If so how much my zip is 23320 please let me know thanks db
dbdbdb
Postby Distant_Midnite » Thu Mar 08, 2018 1:45 pm
Lookin for a radiator pm me if you got one
03 Subaru WRX (sold 5/26/17)
88 ST165 Daily
Distant_Midnite
Postby dbdbdb » Thu Mar 08, 2018 3:32 pm
Hi, don’t have one I got a mishimoto one off eBay a couple of years ago for a little over $100 and it’s been working great fit family well.
dbdbdb
Return to Parts For Sale
