Question about a Camry...
Postby rudeboy3d » Mon Nov 14, 2005 11:07 pm
So I am at work, sitting around doing nothing (as usual) and I took a 99 Camry LE out for a spin. I like the look, its just the whole automatic thing that gets me...
First question would be... Could you bolt a 5 speed Celica tranny to the 5SFE engine in there?
I believe the Camry Solara had a manual as an option, but I know that's strictly a six.
If you can bolt the 5 speed Celica tranny in there, I would think that, in theory, with engine mounts being the same, you could drop in a 3SGTE...
A five speed, 3SGTE-powered Camry would be a fun little family car.
Are any of these swaps possible?
Cause I am looking for a Corolla as a daily driver and make a project out of my Civic, but if I could get a 5 speed Camry, i think I would rather have that. Hondas are easy... Toyotas, I love... Any help would be nice......
Gary, I know you have words of wisdom... You are like Wilson, from Home Improvment... always givin advice over the fence...
bang bang :shoots:
16x vehicle owner... whoooooooooooooo
rudeboy3d
Postby db » Mon Nov 14, 2005 11:25 pm
I'd use the V6 tranny if possible. It bolts up to S-series motors. "Wraith" has a 3sgte swapped Camry. He frequents the MR2 Owners Club (www.mr2oc.com). He had a GT30 in his and sounds like he's going bigger.
Remember that not all states allow transplanting an older engine into a newer car, plus messing with OBDII cars won't be fun.
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Postby Gary » Wed Nov 16, 2005 12:07 am
Instead of the 3s swap, a V6, 1mzfe swap would be much easier and nicer for a daily driver and it'll be smog legal and might be cheaper too. (or just buying a v6 LE?)
93 ST185
Gary
Postby Glenn653 » Wed Nov 16, 2005 7:39 pm
Why not just use the trans out of Celica GT that also had the 5SFE, then just change the head and add a turbo. Or just add the turbo as they have kits to put a turbo on the 5SFE now.
Glenn653
Postby SuperWhite92 » Wed Nov 16, 2005 7:44 pm
Wraith runs a GT4088 now :)
Shaun
SuperWhite92
Postby db » Wed Nov 16, 2005 10:35 pm
I was recommending the V6 tranny as I'm guessing it is probably built beefier coming from a V6 base rather than a 4 cylinder.
Dave
Las Vegas, NV
db
Postby SuperWhite92 » Thu Nov 17, 2005 1:34 am
The beefiest is still the MR2 Turbo Tranny. A V6 should do just fine.
Shaun
SuperWhite92
Return to FWD Celica
