87gts 3sge swapping to stock ct26
Postby buzzbomber87gts » Tue Apr 18, 2006 4:46 pm
I have a few questions...
I have already bought all of the stock alltrac parts for my 87. I got the manifold, ct26, 550cc injectors...everything but an intercooler and piping. heres everything i have:
ct26
550cc injectors side feed
alltrac manifold
iequus 20psi boost guage
1 step colder ngk v-power plugs
i know i need:
downpipe
weld internal wastegate shut
external wastegate
adjustable fpr
255lph pump
fmic
piping
bov
questions:
how do i hook up the boost guage and where does it hook up to?
where do I mount the afm?
how much boost can i run with the stock 9:3:1 compression ratio and a brand new headgasket?
I have the stock ecu so I could keep TVIS so will the turbo mess anything up?
I have been looking at boost controllers, blow off valves, and wastegates and I dont want to spend a lot on any of it i just want to get it done so does anyone have a good opinion on a good one to get?
will i really need the 255lph pump if I get an fpr and use the 550 injectors?
This is my first turbo project and I dont know a whole lot about it, but I am stoked about getting this done. any info about it would be greatly appreciated. let me know guys
um....i need to make my siggy pic smaller :(
87 gt-s 15.06 1/4 @ 92mph
85 gt drift project
buzzbomber87gts
Postby saki10man » Sun Feb 11, 2007 3:31 am
prolly be cheaper to swap an entire 1st gen........it is a straight drop in 8)
1986 FWD 3SGTE(RIP)
2004 Kawi ZX-10
1994 Toyota Pick-up(finished rebuilding :-)
1988 Project ST165(ABANDONED)
saki10man
Postby buzzbomber87gts » Thu Mar 29, 2007 7:52 pm
i have everything i need for the swap but the stock manifold and a tubular manifold i bought both hit the starter....is there anything i can do about this?
85 gt drift project
buzzbomber87gts
Postby 86celicast » Thu Mar 29, 2007 8:06 pm
buzzbomber87gts wrote:i have everything i need for the swap but the stock manifold and a tubular manifold i bought both hit the starter....is there anything i can do about this?
your exhaust manifold right? you could use a 3sfe tranny and that would flip the starter around pointing it towards the battery...or perhaps you could mod. the manifold.
01 IS300
86 ST with 3sge (lease mode)
07 Yamaha R6S-RIP
88 Alltrac ISMA GTO champion #4702-sold
www.myspace.com/86celicast
86celicast
Postby Mafix » Mon Jul 23, 2007 1:54 am
check out st162.com there is a lot of info on turboing a GE motor.
Return to FWD Celica
