5SFE w/ 3SGTE head
5SFE w/ 3SGTE head
Postby celicaGTS_T » Fri Jul 07, 2006 2:25 am
Has anyone or does anyone know if the head from a 3SGTE would swap onto a 5SFE block (1990 GTS), and if so, what is needed to do so??
celicaGTS_T
Postby Maloy » Mon Jul 10, 2006 10:49 pm
Im pretty sure it will, i would go to mr2oc.com. Those guys will know for sure.
88 white st165 (stripped down on jack stands)
86 AE86 corolla gt-s coupe
Maloy
Postby MrWOT » Tue Jul 11, 2006 2:56 am
MrWOT
5SFE w/ 3SGTE head
Postby celicaGTS_T » Thu Jul 13, 2006 1:57 am
Thanks, I wanna go for something that the general public doesnt see happen. Would I have to run an octane rating higher then usual because I'm running higher compression?
celicaGTS_T
Re: 5SFE w/ 3SGTE head
Postby SuperWhite92 » Thu Jul 13, 2006 2:17 am
celicaGTS_T wrote:Thanks, I wanna go for something that the general public doesnt see happen. Would I have to run an octane rating higher then usual because I'm running higher compression?
Boosted or not? You've gotta let us in on a few of your plans so that we can tell you yes or no.
Shaun
SuperWhite92
5SFE w/ 3SGTE head
Postby celicaGTS_T » Sat Jul 15, 2006 12:21 am
It's a 1990 GT-S. I'm debating whether or not to do a half-trac or just swap the 3SGTE head onto the 5SFE block, thats the ideas so far.
celicaGTS_T
Postby Maloy » Sat Jul 15, 2006 5:02 pm
I would use the 3s-gte bottom end because they are already built for boost.
Maloy
Postby MrWOT » Sat Jul 15, 2006 6:12 pm
I'd use the 3S bottom end for a single reason, it's got oil squirters, which helps cool the pistons LOTS!
MrWOT
Return to FWD Celica
