E-brake not holding well. - Updated 11-24-07! - Not fixed!
Postby WarTowels » Wed Jan 10, 2007 2:21 pm
This may apply to the Alltrac, but this is for my GT. I've replaced pads in the front and back regularly. However, my e-brake doesn't hold very well. Even after brand new pads where installed. (I have discs on all fours)
Does the e-brake use a brake shoe system behind the rotor? That would make sense cause I didn't replace that...
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Re: E-brake not holding well.
Postby Gary » Wed Jan 10, 2007 3:08 pm
WarTowels wrote:Does the e-brake use a brake shoe system behind the rotor?
Yes, but it shouldn't cause that (except you frequently drive the car with e-brake engaged)
You can remove the rotor and see what is loose or need to be adjusted.
93 ST185
Gary
Postby turbo4wd » Wed Jan 10, 2007 3:39 pm
Gary's right, I'd remove the rotor,a nd check it out - if needed, there is an adjustment wheel at the bottom which you can fiddle with.
Dan
Undercover Moderator
turbo4wd
Postby Stubble » Wed Jan 10, 2007 5:50 pm
The adjusting wheel is at the bottom of the brake assembly, and you can access it without removing the rotor hat. There is a small rubber plug that covers an inspection hole. You line the hole up at the 6 o'clock position, and you should be able to see a toothed wheel with a flashlight. Rotate the wheel upwards (both left and right sides of the car) to tighten the brake shoes. The instructions for the alltrac are to tighten until the rotor doesn't turn any more, than back off 8 "clicks".
Brady Ryall
1990 ST185 Red - parts
1990 ST185 Black
1999 Miata
2008 A3 Quattro S-line
Stubble
Postby WarTowels » Fri Jan 12, 2007 6:48 pm
Alright, perhaps If I get a nice day out I'll check it out. Thanks.
"(except you frequently drive the car with e-brake engaged)" - Lol, no I don't. I bet you meant unless instead of except. :wink:
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Updated
Postby WarTowels » Tue Jun 05, 2007 7:48 pm
I can't see to locate the notched wheel. I can't get a flash light strong enough to aim and have me see it. Should I just take the rotors off?
-Greg
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Re: Updated
Postby turbo4wd » Tue Jun 05, 2007 8:05 pm
WarTowels wrote:I can't see to locate the notched wheel. I can't get a flash light strong enough to aim and have me see it. Should I just take the rotors off?
-Greg
Yea, once you get the rotor off it'll you'll see the adjustment wheel very easily.
Dan
turbo4wd
Postby WarTowels » Wed Jun 06, 2007 5:23 am
Ok. Sigh. I dispise the upper bolt on the torque plate. I can never get to it, I always have to borrow my friends adapting wrench. Curses!
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby concealer404 » Mon Sep 24, 2007 6:28 pm
Take off your center console. You'll see a cable running down from the e-brake handle. Pull that cable up, and tighten the bolt thingy down. May require some force, probably a friend.
You'll find that the handle won't need to be pulled as far up, and will grab with far more force.
Mine didn't work for years, and my rotor was fine. Happened to see this while stripping the car for renovation and tested the theory. Works fine now, good enough to lock up rear wheels going over 60mph if i'm feeling stupid.
Hopefully i'm not too late!
concealer404
Postby evo » Mon Sep 24, 2007 6:43 pm
please don't do that in an alltrac.
1992/ST185
evo
Postby concealer404 » Tue Sep 25, 2007 11:18 am
I wouldn't, won't, don't, and didn't.
concealer404
Postby WarTowels » Thu Oct 11, 2007 12:51 am
evo - Don't do what he said to fix it, or... don't pull the e-brake at 60mph...
If I could solve my e-brake problem without taking off my rotors (I couldn't figure out how to tighten the part with them on) that would be nice.
My 93 Alltrac also holds like shit on the e-brake.
Putting it in gear is a PIA sometimes. And won't work if I ever get a turbo timer... but I could just get non lazy and take the rotors off.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby evo » Thu Oct 11, 2007 1:09 am
pulling the e-brake while moving can harm the diff
You can try tighten the bolt at the handbrake, that's the first thing you should try to fix your problem.
If that doesn't solve it, there is an adjustment just behind the rear rotors, a star wheel near the studs that hold the rotor in place, you'll see an adjustment hole.
shine a light in that hole, and you should see the adjustment wheel, I forget which way you move it to tighten, but try adjust the same amount on both rear brakes.
If this still doesn't get your e-brake working properly, remove your rotors and check to see you have meat left on your brake shoes. If you need to replace them don't go to Toyota, get them re-lined. I had a set done in Toronto for $30. Toyota wanted almost $300!!
1992/ST185
evo
Postby WarTowels » Thu Oct 11, 2007 2:01 am
I tried adjusting it in the service hole in the rear rotors on my GT. I tried shining a light in there, but couldn't see anything with two different flash lights. I had already put my calipers and brackets back on and they were such a pain I decided to live with it. I'll try the nut on the center console area.
Update:
I went out at 11am, came back in at 1am. I removed the center console and adjusted the top screw to a tension that I felt comfortable. It was night and day in it's holding power on the alltrac. Before, I could pull the e-brake all the way up and the car would roll on almost perfectly flat areas, now about 75% up it holds like a rock.
I almost installed a ground line for a possible amp upgrade over the stock. I like to use the bolts and the metal U bracket under the console. Give a easy, dependable grounding area.
Thanks so much for the help guys.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby WarTowels » Sat Nov 24, 2007 10:56 pm
E-brake handle no longer feels very tight (tensile wise) it was difficult to pull it all the way up after adjusting the screw on the e-brake.
Not it goes all the way up without much effort at all. And the holding power of the e-brake is almost negligent.
On a flat surface, I get slight resistance. On any sort of incline that would make the car roll, it can't hold it at all.
Also, my rear right wheel 'area' seems to be squeaking when going slow. Which seems to have started roughly around the time when my E-brake can no longer hold any sort of weight on it.
Suggestions? Tighten them behind the rotor/service hole? Or just replace the entire brake shoes?
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Return to FWD Celica
