Putting alltrac body kit on my convertible:)
Postby celicaaddict » Fri Feb 09, 2007 4:18 am
i just purchased the complete 88' alltrac flare out body kit,and im gonna put it on my 89' black convertible gt ..
Im also planning on doing a swap and making the convertible turbo :)
does anyone know if the alltrac engine will bolt up to the Gt n/a tranny?[/img]
-Dominick
celicaaddict
Postby Denver_whiteST185 » Fri Feb 09, 2007 4:48 am
It'll bolt up, but they're kinda weak if you push it too much. if you plan on modding the engine, i think that most people modify MR2 trannys or find a manual V6 camry tranny. If your going to drop in a stock 3SGTE, you'll be fine....
^Ted^
Denver_whiteST185
Postby celicaaddict » Fri Feb 09, 2007 5:26 am
thanks ted,ill be doing the body kit 1st soon...ill post pics soon as its all done...i just ordered a aisin clutch for now, should be here soon...are there any strut tower bars for the st165?
-Dominick
celicaaddict
Postby Denver_whiteST185 » Fri Feb 09, 2007 6:29 am
Whiteline makes them. check 935 motorsports or rocketter performance
^Ted^
Denver_whiteST185
Postby at3619 » Sat Feb 10, 2007 8:01 am
as far as the mr2 tranny, all you need to do is switch the shift linkages 180 degrees. but you might be able to find a camry trans for cheaper vs an mr2 turbo trans. Your car should already have the stock st16x strut tower brace. That should be fine
Josh
-2 Twin Super Red 88 Alltracs (RIP my sons...)
-One sweet pile of all trac parts!!!
-00 Celica GTS(B18 Eater)
-1985 Volkswagen Vanagon Westfalia Camper AKA "turtle"
Converted to Syncro(4WD)
Subaru SVX 3.3L H6 swapped!
at3619
Postby celicaaddict » Sun Feb 11, 2007 3:20 am
thanks guys,i cant wait to see how the alltrac body kit is gonna look on the convertible...anyone have pics or heard of someone who did it?
-Dominick
celicaaddict
Postby celicaaddict » Sun Feb 11, 2007 3:26 am
also how are these aisin clutches? i heard theyre not intended for racing performance but considered closer to factory then an aftermarket.
-Dominick
celicaaddict
Postby underscore » Fri Apr 20, 2007 1:38 pm
whered you find the bodykit?
Return to FWD Celica
