7m-GE in a 90 celica gt-s?
Postby nuisy » Thu Oct 28, 2004 4:24 am
would it fit?
rawr dood
nuisy
Postby CMS-GT4 » Thu Oct 28, 2004 4:30 am
One way to find out...
Most people over here know gtfour, and 3sgte. We don't deal much with alternate swaps and such.
I doubt it would fit for a fwd configuration. I would bet that if you cut ou and replaced the floor pan made the car rwd, and modified the firewall, then make custom mounts... it may fit.
For that much $$ just go buy a supra.
Postby smc252 » Thu Nov 11, 2004 12:32 am
Will not fit transversely, like the stock engine did. As you know, it is an inline six, so it is quite a bit longer the the stock i4. If you were to convert to RWD, this swap would definitly work. Personally I am swapping a V8 into my 88 celica alltrac.
1988 All-Trac
(Rotting away, fiending for a tranny.)
1986 Celica GTS
(GT3071R forced 3s-gte + autronic smc)
smc252
Postby MrWOT » Thu Nov 11, 2004 5:36 am
smc252 wrote:Will not fit transversely, like the stock engine did. As you know, it is an inline six, so it is quite a bit longer the the stock i4. If you were to convert to RWD, this swap would definitly work. Personally I am swapping a V8 into my 88 celica alltrac.
Eh? How far along have you gotten on this project? I haven't looked much into toyo V8's, but if that swap worked I would probably do it, I like the 3s-gte and all, but 4 added cylinders would do worlds for smoothness. Not to mention the added torque! Heck, if you have pics of this, start a thread, I'd be very interested to see how this progresses, since I also have an 88 :D
MrWOT
Postby T-spoon » Tue Nov 30, 2004 3:55 am
There's a guy in Australia with a 1uzfe out of a Soarer in his st185. It's not NA anymore, has a snail hanging off each manifold. It's REALLY packed in there, but it fits. I don't know if they had to move the firewall or not.
T-spoon
v8 awd option ? :-)
Postby GMan » Sat Dec 04, 2004 12:56 am
> smc252
> Location: Lafayette, CO
Going to keep it rwd or possibly AWD ?
http://us.lexusownersclub.com/gallery/GS?page=36
http://us.lexusownersclub.com/gallery/GS/AWD_PIC
http://us.lexusownersclub.com/gallery/GS?page=37
http://us.lexusownersclub.com/gallery/G ... RIVE_TRAIN
> 1988 All-Trac
> (1uz sitting in alltrac w/ blower on it)
What blower are you going to Use ?
I was not aware That there was one available for the 1Uz ?
Adapting a GM style, hi top blower ? :-}
Would be Great for low end Grunt,
but a lot of tire smoke without using AWD ?
>1986 Celica GTS
>(60-trim t3/t4 3s-gte + autronic smc)
I guess You Might be able to pull it off.
Quite a Cool swap Rite there. :-)
Regards;
GMan
Return to FWD Celica
