3sge.. to 3sgTe swap..no problem??
Postby the_trooper08 » Thu Aug 30, 2007 3:04 am
if i had a 89 celica GTS... they have the 3sge right...then i could swap in the 3sgte..(entire setup..ecu and all harness..) right??.. im thinkin maybe ...and just use the 3sge tranny..it all bolts up right??
the_trooper08
Postby Mafix » Thu Aug 30, 2007 9:38 pm
you'll have to drill the starter holes and flip the starter to the other side of the bell housing.
Postby the_trooper08 » Thu Aug 30, 2007 11:25 pm
thats it ...sweet
the_trooper08
Postby Mafix » Mon Sep 03, 2007 2:21 am
you may want to read more on that before you jump into it.
Postby 94st3sgte » Sat Jan 05, 2008 4:23 am
yeah theres alot more, but go for it, o and the part with the wiring harness, Doc tweak at http://www.phoenixtuning.com did my buddies harness, best buy he spent on the swap, its made to be easy, and never had any problems putting it in,
94st3sgte
Help
Postby MrMcQuacker » Mon Aug 18, 2008 8:31 am
Hey im on the exact same project but i need to know way more about this swap. i can do it all its just i want to know what exactly has to be done in order for it to be running just fine? can anyone tell me if you can PM me or email me or something please ty
MrMcQuacker
Postby Mafix » Mon Aug 18, 2008 11:46 am
hop over to the 4th gen board. there is a lot of info there.
st162.com
Return to FWD Celica
