HELP JUST DID 3sgte swap and having troubles
Postby mgtcelica » Thu Dec 13, 2007 1:17 am
Hi i just finished getting my Jdm 3sgte that i got from a 92 celica alltrac
installed in my 93 gt celica
ok heres the problems
it idols at 1900 rpms im not quite sure if thats bad or if its cuz of my power steering vaccume line sensors that arent hooked up.
OK but the real problem is
if i floor the gas or jsut give it more than 1/2 throttle as soon as the engine revs to 3500 the check engine light comes on and the engines kinda dies for a second but doesnt stall just kinda sputters
but heres the part that confuses me, if i give the car less than 1/2 throttle and jsut let the engine slowly rev up. it doesnt sputter or stall
PLEASE PLEASE HELP
im kinda lost heree
mgtcelica
Postby evo » Thu Dec 13, 2007 1:24 am
http://alltrac.net/phpBB2/viewtopic.php?t=1111
Follow this, and report back with the code
by the way, did you replace ignition components?
Plugs
Wires
Cap+Rotor
1992/ST185
evo
Postby mgtcelica » Thu Dec 13, 2007 1:34 am
damnit i knew i should of got the engine code, thanks i'll get it tomorrow
no i only replaced the spark plugs
mgtcelica
Postby Mafix » Thu Dec 13, 2007 2:17 pm
sounds like a terrible vacuum leak. i'd look there and stop running the hell out of it. also sounds like you are knocking.
Postby mgtcelica » Sat Dec 15, 2007 7:55 pm
ok i did the diagnostic check
it said code 34 and code 35
which are the turbo pressure sensor
the vaccumm lines that go to my powersteering pump to tell the ecu when to idle up are broken could this be the problem
mgtcelica
Postby mitt4g » Tue Dec 18, 2007 6:12 am
So did you figure out what was wrong?
1988 GTS Swapped in 2nd Gen 3SGTE----- SLEEPING UNTIL IT GETS HUNGRY !
mitt4g
Postby mgtcelica » Thu Jan 03, 2008 1:51 am
ok 2 problems/ ideas
is it possible that i am having boost problems because i didnt put any exhaust on my car yet..
and i got the motor to kinda run correctly
but i think i blew out the diff in the center transfer case since i dont have a rear output shaft.
i think i broke that differental since i didnt give it any resistance.
please
help
mgtcelica
Postby evo » Thu Jan 03, 2008 2:05 am
you're using the AWD tranny? and you didn't convert it to FWD?
That's a problem, there is lots of documentation on transmission options if not here check celicatech.com
You'll need a FWD transmission, you probably destroyed that one
1992/ST185
evo
Postby mgtcelica » Thu Jan 03, 2008 2:22 am
ok well if i remove the center transfercase and diff.
and install an axle shaft from a V6 camry will i be alright
mgtcelica
Postby syko says » Thu Jan 03, 2008 2:27 am
what happened to your other tranny? the one that was originally in the car? automatic? manual? you can use the stock tranny, it bolts right up. given that its 5 speed. (dont quote me on that, im not very sure, but at the same time, i am sure lol)
Aloha,
Evan
syko says
Postby mgtcelica » Thu Jan 03, 2008 2:32 am
i replaced an automatic 5sfe
with a 5 speed jdm 3sgte
kept the alltrac tranny intact just removed the rear drive pinion out of the transfer case and made a plate to go over where it attached
mgtcelica
Postby Carolina91GT-S » Mon Jan 07, 2008 3:24 am
mgtcelica wrote:i replaced an automatic 5sfe
If you do this then you must also switch the mode lever to FF mode, if you don't then the center differential will try to push all force to the rear wheels and you will go nowhere.
Carolina91GT-S
Postby Carolina91GT-S » Mon Jan 07, 2008 3:25 am
evo wrote:you're using the AWD tranny? and you didn't convert it to FWD?
Why couldn't you use the AWD tranny if you move the mode selector lever to FF mode for front wheel drive and remove the pinion?
Carolina91GT-S
Postby evo » Mon Jan 07, 2008 3:46 am
http://www.celicatech.com/forums/showthread.php?t=11171
This is a good read. What I was suggesting was that he couldn't use the transmission without converting it to fwd, I wasn't aware that he had already attempted to
1992/ST185
evo
Postby mgtcelica » Mon Jan 07, 2008 4:17 am
well i did try putting it in 2 wheel drive mode i think thats with the selector down right? i took the rear end gear out of the transfer case and blocked off the back of it with a custom machined plate of aluminum
mgtcelica
Return to FWD Celica
