HELP JUST DID 3sgte swap and having troubles
Postby mgtcelica » Fri May 23, 2008 10:56 am
.well i ended up running the stock gt trans and its working so far
beforeImageafterImage
mgtcelica
Re: i've done it so this is whats up
Postby Carolina91GT-S » Fri May 23, 2008 6:51 pm
mgtcelica wrote:First you are going to need to remove the ring gear from the center diff, you know the thing that goes to the rear end. and plate that off. dont worry it works. BUT DONT PUT THE DIFF IN 2WD mode leave it in all wheel. but this way you will only need your 2 front wheels and axles. thats the axles from an alltrac. they fit .
I have wanted to try this but I understand that the center differential is open, meaning that...in AWD mode all the power will be put to the rear wheels since they have no traction(being disconnected) So you would rev, in gear, the tranny would turn but the front wheels won't.
Please explain how you did this and how it works because it shouldn't
Carolina91GT-S
Postby mgtcelica » Fri May 23, 2008 7:47 pm
i welded the center diff together the diff held up but the diff lock sleeve broke after 400 miles of driving
the locking sleeve is a 90ish dollar part
mgtcelica
Postby Carolina91GT-S » Fri May 23, 2008 8:54 pm
ok so you didn't just blank of the transfer gear and leave it in AWD mode. I read back in your previous post also that you had welded the diff.
So you are saying that with the diff welded up tight and in AWD mode that the locking collar broke? seems strange, There are alltrac guys out there running some bug HP. I would think that stock the locking collar could handle it all to just the front 2 wheels.
Carolina91GT-S
Postby mgtcelica » Fri May 23, 2008 9:37 pm
well i'm just saying what happened 86 me
mgtcelica
Return to FWD Celica
