I need help Please
I need help Please
Postby patchat88 » Fri Dec 28, 2007 11:49 pm
Hi, I have done a 3sgte swap in my 90 celica. and now he start perfectly, idle OK but when I hit the gas too fast hey seem to missfire at 4000 rpm and when i slowly push on the gas i can take it to 5500 rpm but I have all ignition compenent new and i think am not suposed to have the rev limiter at 5500 so if some one can help i will be the happiest guy on earth lol
patchat88
Postby RedCelicaTRD » Sat Dec 29, 2007 12:03 am
Did you replace the stock fuel pump?
Postby patchat88 » Sat Dec 29, 2007 2:48 am
yea I have a walbro 255lph
do you think it can be a clogged fuel filter or injector ??
patchat88
Postby RedCelicaTRD » Sun Dec 30, 2007 3:47 am
A clogged fuel filter is possible. And even if your fuel pump is new, don't rule it out. I know that Walbro had a couple batches of crappy pumps a few years ago.
Postby syko says » Sun Dec 30, 2007 5:34 am
Any CELs?
Aloha,
Evan
syko says
Postby patchat88 » Sun Dec 30, 2007 7:02 pm
no cells and on my wideband when he missfire i have 10.1 ratio so am not lean am rich so I have gaz
and its normal at idle i have 11.1 its normal ??
patchat88
Postby patchat88 » Mon Dec 31, 2007 4:52 pm
bump
patchat88
Postby Mafix » Mon Dec 31, 2007 7:01 pm
sounds like it's time to test the AFM.
Postby Corey » Mon Dec 31, 2007 7:05 pm
^^ plus 1
are the plugs gapped correctly?
Corey
Images: 50
Postby hacker_720 » Tue Jan 01, 2008 1:22 am
here's a simple one to put on your list:
all grounds ok?
BOTTLE ARE FOR BABIES...REAL MEN GET BLOWN
1990 ST185 2.2Lt
hacker_720
Postby patchat88 » Tue Jan 01, 2008 10:15 am
I have clean my afm and tested and they are on the spec of the bgb I will try it tomorow and my plug are brand new cooper gapped at 0.028 and for the ground i have check to the ecu and i have ground on all specified place so am really confuse
patchat88
Return to FWD Celica
