Wiring Harness question
Postby Terracar » Thu Jan 31, 2008 3:29 pm
Hello,
So I have the shell all prepped for swap, but I have a question on the wiring harness.
I read that there is two harnesses - the engine harness and the chasis harness. Do I have to remove both harnesses and have the rewired for the motor or do I just need to have the engine harness rewired? (rewired since JDM motor) :shrug:
TIA!
-Terra
Terracar
Postby C.R.3.A.M » Sun Mar 02, 2008 3:51 pm
only the engine harness!!!! :D
C.R.3.A.M
Postby Carolina91GT-S » Tue Mar 11, 2008 8:17 pm
I'll have to disagree. The wiring changes are done on the chassis side usually, it is easier that way. The Engine harness will need to be extended, some parts may need to be shortened depending on your method. They both will require some changing.
These things are based on the idea that you are removing the 5S engine from a USDM FWD 5th gen celica and replacing it with a JDM 3SGTE. Is this what you are doing? if not then disregard.
What are you doing transmission wise?
Last edited by Carolina91GT-S on Tue Mar 11, 2008 10:21 pm, edited 1 time in total.
Carolina91GT-S
Postby C.R.3.A.M » Tue Mar 11, 2008 8:57 pm
well i didnt this swap and ive put a camry v6 tranny...fit well but the only prob is the left side axle shaft
C.R.3.A.M
Postby Carolina91GT-S » Tue Mar 11, 2008 10:22 pm
You did or did not perform this swap?
Carolina91GT-S
Postby C.R.3.A.M » Wed Mar 12, 2008 12:27 pm
yes i did lol... srry wrong type :D :D
C.R.3.A.M
Return to FWD Celica
