5sfe engine build up and possible turbo
Postby eschie22 » Wed Feb 20, 2008 5:07 am
hey i was just wondering if any of you guys have a 5sfe 90' celica gt-s and if so have you built it up or just done a 3sgte swap? if you have done a build up id like to know of some good places to find internals and what not. Thanks for the help
eschie22
Postby syko says » Wed Feb 20, 2008 5:20 am
This is a common question that people on here like to ask when someone is building an engine (well everyone should ask themselves this)
What are your goals for the engine?
Aloha,
Evan
syko says
Postby eschie22 » Wed Feb 20, 2008 7:31 am
well im hoping to make it a good car for auto cross or something along those lines. so quick get up and go.
eschie22
Postby Sifu » Wed Feb 20, 2008 3:29 pm
You'll have better luck over at the other Celica forums. Most of us have Alltracs.
It can be done but it's usually not a smart route boosting a 5sfe. It's one of Toyota's best engines when it comes to reliability but add turbo into that equation and things usually go boom.
For the cost of a 3sgte it's still MUCH easier to swap out the engine and plus the aftermarket support (which is small for our community) is still larger than the 5sfe crowd.
Also if you're wanting to AX then the Celcia GTS would be better suited than a swapped 3sgte. You will get handed when they bump you up classes...
BROKEN! BUT NOT BEATEN!
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby darthripley » Wed Feb 20, 2008 6:20 pm
moved to turbo fwd.
there is a ton of info regarding 5sfe N/A builds and turbo 5sfe builds on celicatech as well as mr2oc
if you're interested in the turbo route check out pressure2 - he is one of the few who have successfully boosted a 5sfe without the kaboom.
personally for auto-x i would go a mild N/A route so you can stay in a class where your car will be more competitive as opposed to facing off in a class with vettes etc.
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
6gc
Postby GMan » Thu Feb 21, 2008 3:01 am
> darthripley
> Location: dallas, tx
> Posted: Wed Feb 20, 2008 6:20 pm
I follow www.6gc.net
6th gen celicas.
> he is one of the few who have successfully boosted a 5sfe without the > kaboom.
You'll find pressure 2 on 6gc.net :D
I got a ride in his car. Damn fast for what it is.
Less weight and more Torque than a 3sgte.
If you are after all out power, the 3sgte is probably better in the Long run.
The 5SFTE does ok, on a budget. If done right, it can be Very reliable.
Regards;
GMan
Postby darthripley » Thu Feb 21, 2008 3:50 am
^ correct on 6gc.net - i didn't even think of that earlier :doh:
the torque numbers are very impressive indeed ... most impressive of all is the longevity & reliability of pressure2's build in my mind.
Female Moderator
darthripley
All Trac Goddess
Postby presure2 » Thu Jan 01, 2009 10:34 am
thanks for the props guys!
you wanna see some serious 5sfte performance, look up supershannon77
on 6gc.
i put together a setup for her in a 6gc, useing one of those cheapo ebay knockoff, ran it up to 16.7 psi, and made 285whp and 300ftlbs.
:smokes:
http://www.6gc.net/forums/index.php?sho ... 2431&st=80
the dyno chart is at the bottom of the page.
www.6gc.net for all things 94-99 celica related
presure2
Return to FWD Celica
