SW20 gearbox in my ST202t
Postby Sthen » Mon Mar 03, 2008 9:51 am
Hi to all,
after swapping the 3sgte (st205) in my st202..with minor mod...i'm not able to manage power...
We're thinking to use an SW20turbo gearbox (with stock LSD)...
Somebody can tell me if can fit correctly in my car??
All your info can be usefull :)
regards
Sthen
Sthen
italy
St202-3sgte inside
2wd power
Sthen
Postby scothaniel » Mon Mar 03, 2008 7:44 pm
Check the 6gc.net site, lots of info there on using the MR2's E153 trans in the ST202. There's an issue with the passenger side axle length, but its easy to solve.
http://www.6gc.net/forums/index.php?showtopic=40114&st=0
http://www.6gc.net/forums/index.php?showtopic=32626
http://www.6gc.net/forums/index.php?showtopic=48413
Which version of the ST202 do you have? Do you have the version w/ super struts?
Scott
Michigan
scothaniel
Postby Sthen » Mon Mar 03, 2008 8:56 pm
My st202 don't have superstrut.... standard suspension
tnx for the link....i hope to find all the info...and after all the parts :)
Sthen
italy
St202-3sgte inside
2wd power
Sthen
Postby scothaniel » Mon Mar 03, 2008 9:19 pm
Good luck with the swap.
If you decided to try the ST202 SS2 (w/ super struts) Celica axles I mention in that last link, let me know if they work. I wanted to try those on my ST202, but I couldn't find anyone to import the parts for me. They are one piece from trans to hub, so you wouldn't have to mate MR2/Celica/Camry axles together.
Also, I've found the stock rear transmission mount to be pretty weak. I have a few mods to my 3S, and the amount of front-rear engine movement - even with new mounts - is horrible. I plan on replacing the rubber with urethane in the front and rear mounts.
Scott
Michigan
scothaniel
Postby Sthen » Fri Mar 14, 2008 10:29 pm
e153 bought
st205 mount already at my home...
now i need to find sw20 axles and st185 axle..
but the issue abot the lenght is only for passenger side??
for the left axle i can use my stock st202????
Sthen
italy
St202-3sgte inside
2wd power
Sthen
Postby scothaniel » Fri Mar 14, 2008 11:25 pm
Stock ST205 or ST185.....
Scott
Michigan
scothaniel
Postby Sthen » Sat Mar 15, 2008 9:08 am
at the end
LEFT
only ST185/205 axle
RIGHT
SW20 inner
ST185 or Camry V6 outer
Sthen
italy
St202-3sgte inside
2wd power
Sthen
Postby Celicatuner92 » Thu Apr 17, 2008 1:46 am
you must use both the sw20 parts that go into the transmission because they are much larger than the axles of an alltrac.
i know this cause i just finished one yesterday.
90 St185_DD actual car seen on tirerack.com
90 St185_ race car
92 Celica Gt_Runnig
Celicatuner92
Return to FWD Celica
