1st gen 3sgte in mr2
Postby str8upclownen » Wed Mar 26, 2008 7:07 pm
Hey just wondering if an 88 celica all-trac 3sgte will fit in my 91 na mr2 and will this be an easy swap?could i use my 5sfe tranny? would i need all the celica's wiring harness? what other parts would i need to buy or use?
str8upclownen
Postby GMan » Wed Mar 26, 2008 10:17 pm
> str8upclownen
> Posted: Wed Mar 26, 2008 7:07 pm
> Post subject: 1st gen 3sgte in mr2
Yes it will fit. But that model 3sgte was never offered in the MR2.
It makes it a Bit more complicated ?
Would need the ecu and wiring harness...
If you have to ask, it is not. :(
Have you done any other engine swaps ?
Yes you could use it.
Yes; ECU harness at Least.
How complete an engine do you have ?
If you got a front cut, it would make it a bit easier
since you would not have to search for any needed sensors.
I would guess you would at Least need the MAP sensor. AFM
etc...
Much more info on the MR20c.com ...
Good luck.
Regards;
GMan
Postby str8upclownen » Wed Mar 26, 2008 10:43 pm
it's cause my brother has an all trac and he's going to part it out and he said he'll give me the engine so i got a complete motor. nope never have done in engine swap but there's always a first :D
str8upclownen
Postby str8upclownen » Thu Apr 03, 2008 3:32 am
thanks
str8upclownen
Return to FWD Celica
